Question about Samsung SyncMaster 910T 19" LCD Monitor
I HAVE A 19' MONITOR FROM SAMSUNG
THE PRINT IS TO LIGHT AND IT IS HARD TO READ ON THE SCREEN & ALSO WHEN I PRINT IT PRINTS LIGHT. I LIGHTEN THE SCREEN, BUT IT SEEMS NOT TO HELP & THEN I TRY TO DARKEN FOR THE PRINT SAME WAY. THE PRINT NEEDS TO BE DARKER & I TRIED TO CHANGE FONTS & SAVE, BUT IT WAS THE SAME.
  • Samsung Master
  • 4,924 Answers
If the fonts are too small ..just see the resolution maybe is too high and thats why ..being a 19' monitor you should use it at 1024 x 768 resolution to be accesible with big fonts ..and still not too big..and the luminosity and contrast have to be adjusted from the monitor itself in order not to affect all the stuff you get out from the computer ...when you Modify it from the video card you change all that will run on the computer and all its properties..
So ..if it is not a issue with the resolution ...just encrease the font size from right click on the desktop and choose properties..there on the appearance you will have settings for all...just go to the advance settings inside..and you can modify the font for each bar ..for the icons..and the icons itself ans still use a high resolution ..
also you can change all fonts to a bigger value by going into the desktop properties and instead of going to the appearance go to settings ..(the last one in the right ) and there click advanced and change the DPI from 96 normal ...choose custom ..and add a percentage to encrease the fonts and icons as well all at once and the fonts too ...
For the fonts use on the browser the settings are made from the internet options ..in the browser itself..
Posted on May 14, 2010
Why is the colour in my photographs not printing as they are in my laptop I have added new inks and cleaned the printing heads
Anonymous, there's a whole science of "color management" that you've invoked. First, what you're seeing is truly caused by lack of "calibration" in any stage of your workflow.
Your camera takes pictures, and whatever colors it sees are what it sees.
Your monitor shows you colors, but there's no standard calibration involved.
Your printer prints colors, but it too isn't calibrated to any standard.\
Assume for a minute that your monitor is set up to be a little too dark. You edit the pictures, and lighten them up so they look ok on screen. Now, when you print the picture, it's too light.
I've had similar issues, and have ended up purchasing a monitor calibration tool (Color Munki Smile) to calibrate my monitor, software "Profile Prism" to calibrate my printer, and now the prints I get look almost exactly like what I see on screen...
Sep 11, 2014 | Canon Pixma iP4500 InkJet Printer
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
I have a Samsung SMT-190 19" FLAT PANEL monitor and the picture won't show but a few minutes and then a sound comes on and the power light is blinking and the picture goes out and leaves only the blank...
More then likey yuor Inverior Board is going bad if not that, Its the Power Board
First check Invertor This Happens a lot Its hard to find someone to fix it.
Well I had a hard time. I just waited and bought one for parts and fixed it Myself
Good luck
PS. You can still use it just get a different Monitor. The Video out on the Samsung to the
Video in on a different Monitor IT WILL WORK
Jul 13, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
How do i lighten the screen ...it is so dark i can hardly read the print
If your screen is that dark when it boots up, you may have lost the inverter that supplies the increased voltage to run the screens backlight. The commands for the lightening and darkening the screen are as follows.....
<Fn> and up-arrow key Increases brightness
<Fn> and down-arrow key Decreases brightness
May 24, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Having trouble powering up my Viewsonic VX922. See the analog data, but have to power down for 20 sec (several times) to get the digital data on the screen
bob_loopeker, If you know that your pc is ok with different monitor then you will need to inspect the power supply board inside your VX922. All you need in the way of info is here on fixya!! All you need to do is read and make decision on what to do. Spend some time reading in my fixya profile or do "ctrl" key and click on "vx922 19" monitor" that is highlighted in light blue text above. May need new capacitors installed on unit's "switch-mode-power-supply" printed circuit board. hopre this helps. 12fixlouie
Mar 17, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Photos look great displayed on monitor but when I go to print them they are dark. I have to spend ages lightening them up. Any solutions.
Hi
you may check the print settings by going to printing preferences after right clicking the printer icon in printers and faxes and clicking onproperties
it will also allow you to get a preview before the print and hence you cn check the print quality
if you still get dark printout,try power fleeing and partial reset of the printer and see how t works.
Thanks & regards
Jul 14, 2009 | Canon PIXMA MP610 InkJet Printer
To light of print in part of Letters
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Balance CM2019 19" LCD Monitor
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Samsung SyncMaster 910T 19" LCD Monitor Logo
120 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
