Question about DeLonghi MW 535 Microwave Oven
Microwave oven & grill ac925efy
Have power ,put microwave on ,set time goes round but nothing gets hot . bought at argos about year ago
  • 6,487 Answers
If you want to fix it yourself you'll need some understanding about what you're going to do.
If absolutely everything is working and food stays cold, there's only one problem MAGNETRON. You'll need to disassemble the microwave itself, remove the magnetron an to replace it with the same type.
Be advised That this might be expensive. In some cases magnetron costs more than new microwave oven but to avoid further damage to this unit and you don;t have any experience fixing a unit like this better have it check to a service center near you for your safety also.
Posted on May 14, 2010
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
Delonghi ac925efy working but making noise all the time
This indicates a triac switching semiconductor problem, the triac is a switching device that allows the microwave oven to run on different power settings, if the defrost cycle is running on a higher power level it is most likely the semiconductor, but the possibility remains that the keypad control board may be the issue.
Apr 14, 2012 | DeLonghi Microwave Ovens
I bought Cook's Essentials cook ware many years ago and I have 2 pieces that need to be replaced but i have no idea how or where to send them to be replaced under lifetime warranty, can you help.
There doesn't apear to be a web site for the company. I can only suppose that it is just a trading name.
Try speaking to Argos or QVC.co, for advice but "Lifetime Warranty" doesn't mean anything. The LifeTime of the product could be 21year for instance and probably won't cover anything that has broken.
Have a try, nothing to lose.
Jan 02, 2011 | Microwave Ovens
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Hi, I've got a 3-year old Panasonic NN-A725M microwave combination cooker. It has stopped microwaving! The interior light works, the motor works, the turntable turns, it feels hot inside, but the food is...
You need a magnatron..IT shoud be under warrenty..Magnatronshave 5 yrs warrenty..Contact you local service center..all you should have to pay is labor
Nov 28, 2008 | Microwave Ovens
Bought a brand new whirlpool microwave/convection oven 2 months ago. Model GH7208XRS-1. Was using it to reheat food for 2 minutes. Food was not hot enough, so put it in for 1 more minute. When I closed the...
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it's still dead, since it's under warranty I would contact Whirlpool customer service for a free fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 12, 2008 | Whirlpool Microwave Ovens
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
DeLonghi MW 535 Microwave Oven Logo
170 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
