Question about Oasis Switch
I need a wiring diagram for model # CRBIP 97171399
My water cooler cord has been damaged from 6 years of being moved around. While disconnecting the Black & Red wires from the thermostat area I did not mark them & have NO idea which wire goes where. Please send me a wiring diagram
scottschaaf7720yahoo.com
or Please call at
1 987-258-2887
Thank you for your time.
Susan
  • 843 Answers
If you have only two wires and two terminals, it doesn't matter which one is which.
The thermostat is a switch. Your black and red wires would be the input and output to that switch. One is always hot, the other is hot only when the thermostat is calling for cooling, that is, when the switch is closed.
Posted on May 14, 2010
Side by Side water dispenser would not stop
You will need to replace the switch. Here is the part to order.
To replace the switch:
Here are the basic instructions: " 1. Unplug the refrigerator power cord. 2. Remove the overflow grille from the housing. 3. Unsnap front cover at the bottom of the housing. (You'll need to insert the tip of a flat blade tool into the slots molded into the bottom edge of the facade and twist or pry out,you may want to use some type of pad to eliminate damage to the door panel). 4. Disconnect the front cover switch harness connector and set the cover aside. 5. Disconnect the power wire harness connector (BL/BK and W wires) 6. Disconnect the flapper door heater wire harness connector (if one is present). 7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart."
Oct 31, 2012 | Whirlpool Refrigerators
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
The radiator has one holding bolt at the top and rubber mounted grommet at the bottom. Removal of the top bolt enables the radiator to swing forward but cannot be moved out of the way to get to the spark...
I use a SnapOn Universal joint coupling Plug spanner. With that, I can get in at odd angles.
Method.
Be careful not to damage the oil cooler and radiator fins!
Remove, Lower and upper cowl and wind guard.
Remove oil cooler upper mounting bolts and wire harness guide.
Disconnect fan motor sub harness (2 pin) and remove radiator upper mount bolt.
Remove the radiator from the upper and lower brackets by moving it to the left, then move the oil cooler forward as an assembly.
Remove the air guide from the oil cooler bracket and cylinder head cover.
Disconnect the spark plug caps.
Clean the area with compressed air to ensure no debris enters the engine.
Remove the plugs and check/clean/set/replace.
Jan 08, 2011 | Honda CBR 1100 XX Super blackbird...
Where do I find a diagram to change the power steering pressure line hose in my 1990 Lincoln Continental?
REMOVAL
  1. Disconnect negative battery cable.
  2. Remove sight shield.
  3. Remove module bracket.
  4. Disconnect No. 6 spark plug wire to prevent damage to wire.
  5. Remove radiator fan shroud assembly.
  6. Remove top RH isolated radiator mount bracket.
  7. Remove remote air cleaner.
  8. Remove ignition coil.
  9. Disconnect electrical connector on power steering pressure switch at steering gear.
  10. Remove pressure switch to allow for tool clearance.
  11. Remove screw at pressure switch and return line bracket.
  12. Remove anti rattle clips from power steering lines.
  13. Remove plastic strap attaching steering gear heat shield to power steering return line.
  14. Remove plastic strap attaching lines to transfer tube on the steering gear.
  15. Disconnect Electronic Vacuum Regulator (EVR) valve wire.
  16. Remove the ground wire from back of engine block.
  17. Remove pressure line fitting at power steering pump using a 5/8 inch flare nut wrench.
  18. Loosen clamp and remove return line at pump.
  19. Loosen clamps and remove return line at power steering oil cooler.
  20. Remove pressure line fitting (gold in color) at steering gear, using an 18mm open end wrench.
  21. Remove return line fitting (silver in color) at steering gear, using an 18mm open end wrench.
  22. Loosen two screws retaining power steering oil cooler to sub frame.
Oct 21, 2010 | 1990 Lincoln Continental
I need a spark plug wire diagram for 1987 ford 302 crown vic
1987 Ford Crown Victoria 5.0L FI 8cyl
Duraspark Type Plug Wires
The spark plug wires used with the Duraspark type ignition system are 5 / 16 in. (8mm) in diameter to contain the higher output voltage. There are two types of wires used in this system, and some engines may have both types installed. It is important to properly identify the type of wire used for each cylinder before replacements are made.
Both types are blue in color and have silicone jacketing. The insulation material underneath the jacketing on some plug wires is a silicone layer separated by glass braid. The plug cable not incorporating the silicone layer is used where engine temperatures are cooler and are identified with the letter SE with black printing. The plug cables with the silicone insulation are used where high engine temperatures are present. These cables are identified with the letters SS with white printing.
Each spark plug cable, if original, is marked with the cylinder number, model year and date of cable manufacture (quarter and year). Service replacement wires will not have cylinder numbers, or manufacture date.
On any vehicle equipped with a catalytic converter, never allow the engine to run for more than 30 seconds with a spark plug wire disconnected. Unburned fuel in the cylinder may ignite in the converter as it is exhausted and damage the converter.
When removing spark plug wires, mark and tag the individual wires. Grasp, then slowly, twist the insulator back and forth on the spark plug to free the insulator. Do not pull on the wire directly as it may become separated from the connector inside the insulator. Special tools are available which can help ease plug wire removal, and prevent damage to a cable.
When installing a new set of spark plug wires, replace the wires one at a time so there will be no confusion. Start by replacing the longest wire first. Route the wire exactly the same as the original.
Fig. 1: 6 cylinder engine-240Firing Order: 1-5-3-6-2-4Distributor Rotation: Clockwise
Fig. 2: 8 cylinder engine-255, 302, 351, 400Firing Order: 1-5-4-2-6-3-7-8Distributor Rotation: Counterclockwise
Fig. 3: 8 cylinder engine-390, 427, 429, 460Firing Order: 1-3-7-2-6-5-4-8 DistributorRotation: Counterclockwise
Visit autozone.com (free register) for more details.
I hope helped (rememer rated this) Good luck.
Oct 15, 2009 | 1987 Ford Crown Victoria
Cooling does not work either
Get in there with a vacuum and clean up the condenser coils then check the compressor relay. If all those are fine bypass the cold control just long enough to see if the water cooler works. Do not leave it bypassed or damage to the reservoir could occur.
Aug 31, 2009 | Hamilton Beach Water Cooler with Storage...
SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ hateandlove_1988@yahoo.com
May 23, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
WE HAVE A COLEMAN 5640 PORTABLE FRIDGE. WE HAVE ONLY USED IT TWICE, AND JUST GOT IT OUT FOR A WEEKEND TRIP(TO PUT INSULIN IN)BUT IT ONLY HEATS UP, NOT COOL. ANY IDEAS? wE HAVE BOTH THE CAR ADAPTER AND...
I bought one but it was missing the cord, so I hooked it to the benchtop supply. I found out if you place positive to the red terminal/grey wires under the outside cover and negative to the blue/black wires it cools. With a DPDT switch and a couple of LEDs you could wire it so you dont need that special coleman cord, any lighter cord will work provided it can handle about 6 amps, I recommend 12 to 14 gauge wire and a 6 amp fuse.
Jul 18, 2008 | Coleman Refrigerators
Oasis Switch Logo
79 people viewed this question
Top Oasis Electrical Supplies Experts
Steve
Gene Haynes
Are you an Oasis Electrical Supply Expert? Answer questions, earn points and help others
