Question about Toshiba TP55H60 55" Rear Projection Television
The power lamp flashes when turned on, no picture???
I have atoshiba 1999 model tp55h60 itwont stay in spite of replacing fuses are 250v 3 amp too strong or are 125v 7amp good for it?
Posted on Jun 12, 2010
  • Toshiba Master
  • 8,457 Answers
Ur tv needed a new lamp.Ur current tv lamp,in the tv now.U used the tv about 4 or 5 hours a day.Like the last 1 1/2 or 2 years the tv in used?The lamp life span is over.
Posted on May 14, 2010
Testimonial: "Thanks I will order a lamp & replace it."
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
Negative picture,lamp indicator flahing 3 minutes after turning tv off
sounds like your system board is really shot ....did you have a power glitch recently? got backup?
Feb 11, 2008 | Sharp 65DR650 65" Rear Projection...
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Takes to long for unit to come on, when pressing power on remote, green light comes on, but it takes over an hour for the picture to come on.
could be a lamp problem, turn the set off, watch the front led light next to LAMP, count how many flashes in sequence, eg. 2 flashes indicate lamp problem, 3 flashes internal overheat problem. if a orange light flashes next to POWER indicator you have a power malfunction.
Aug 22, 2010 | Panasonic PT-61LCZ70 Television
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Lamp power supply board on Panasonic PT-50LC13 mulfunction.
You can purchase the lamp supply thru "Encompassparts.com... The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
Apr 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Toshiba TP55H60 55" Rear Projection Television Logo
387 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
