Question about Hayward Aquabug Above Ground Pool Cleaner Hay500
My aqua bug does not stay on the floor of the pool it comes off of the floor and gets pulled around the pool by the hose and i hav submerged it in water before hooking it up
  • 640 Answers
If the pool cleaner is not staying properly sealed to the floor, it is very possible that it is a problem with the water flow. Make sure that you have adequate flow (clean all of your baskets, filter, and throat of the cleaner). You will also want to make sure the the pool cleaners shoes and wings are not worn or damaged. Replace them if necessary.
Posted on Dec 05, 2011
What can i do to get my Zodiac Kreepy Crawley to submerge under the water to clean the bottom of my pool
Check to see that the hose weights are attached. There should be a weight in the middle of the fist 3 sections of hose from the cleaner.
May 16, 2014 | Universal Kreepy Krauly In-Ground Pool...
Looking for instruction manual
Here is a copy of the users manual for the Aqua Bug pool cleaners. Hope this helps.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Jun 19, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
I have the hayward aqua bug automatic pool cleaner. My problem is this, it seems to stay at one end of the pool and knots the hose up. Not sucking the dirt up, and eventually quits. Can you tell me what is...
If the cleaner is not moving properly, you probably need to replace the shoes or the wings. If either of these is worn, it can cause improper coverage and movement (which could also cause the hose to tangle). If you are storing the pool cleaners hose in a coil position, stop doing that. To correct, lay the hose stretched out in the sun on a warm day. It will allow the hose to return to its correct shape. If it is not sucking up dirt, it could be a water flow problem also. Make sure that you have sufficient suction and make sure that the cleaners throat is not blocked.
Jun 02, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
My creepy crawley will not pulsate, or does for 5 minutes then stops pulsating but keeps on sucking. I have read a few complaints and from what I can gather, I need to replace the flapper valve. What is...
ok first of all the flapper is located right in the center at the bottom of the creepy crawley. Pull it out of the pool turn it upside down and you can actually move it with your hands and it will feel like it loose and not really connected. Anyhow check in the mouth - opening for any kind of obstuction (leaves,twigs or anything foreign that may be causing it to fail. There can be something flopping around inside causing it to work sporadic or the flapper may need replaced however I doubt that. Next you need to check your circulation. Is there to much suction? this would cause it to stay in one spot and not move. Do you have an air leak causing the pump to lose prime and then regain it over and over? There are two ways you can check for air. At the pump basket - if you have a clear top can you see bubbles or on your return lines to the pool is there bubbles coming out? To much circulation and poor circulation can cause the creepy to do weird things. When was your filter last cleaned? Is there the required amount D.E. inside? Have you backwashed the filter at all? The last thing to check would be the hoses connected to the creepy crawley. Some hoses become loosly connected and start sucking air. Some hoses rub along the plaster continuously in the same spot causing holes. Although unlikely, poor water chemistry - chemical damage can cause hoses to deteriate over the years.
I hope this helps. Please feel free to submit any further questions you may have and I will be glad to answer them for you. Good Luck!!
Dec 08, 2010 | Universal Kreepy Krauly In-Ground Pool...
My bull shark does not move around anymore. I was advised I had to put weights on it but all this does is keep it in one area of the pool. There is a suction noise at the weir as well. What could be the...
Slow moving or stationary cleaners usually do not get enough suction from the skimmer. Inspect the hose to skimmer weir connection for leaks - sometimes the hose end can be worn or cracked, allowing it to **** air. Check the hose for obstructions and check the hose connection to the cleaner. Lastly, if all suction hose items check out okay, check the drive belt tension and condition.
Nov 18, 2010 | Aqua Vac Tiger Shark
Vacuum
ok, if u connect the vacuum plate to the skimmer then u need to submerge the hose all the way or the way i do is use the water from the return ( where the clean water returns to your pool and put the hose up against it to where the hose is filled with water and it will sink a little bit, This gets all the air out so it will be easier for the vacuum to get suction. Once u get the water in the hose by either submerging it or using the return water then connect the vacuum plate and then put it on the skimmer...it should start suction right away but if it doesnt that means u didnt fill the hose up all the way or u may need to just giggle the hose a lil to get it to start the suction....I hope this helps, let me know
Thanks and God bless
Jun 23, 2010 | Intex Easy Set Pool 15x36
My aqua bug doesn't move
Check to make sure that you do not have any obstructions in the wheels/gears. Also, make sure that you are getting adequate pressure going into the aquabug. If you have an obstruction or are not getting adequate pressure, this can make these automatic pool cleaners disabled.
Jun 14, 2010 | Hayward Aquabug Above Ground Pool Cleaner...
My pool navigator will not stay at the bottom its always coming to the top to clean and hovers there.
if by saying at the top you mean running around the top of the walls then reduce the suction on the vacuum by opening another valve slightly... if by at the top you mean floating around in the water then make sure the vacuum is getting enough suction.... it can be a number of issues causing loss of suction but most likely is going to be too many sources on suction side of pump.
May 31, 2010 | Hayward Navigator Pool Cleaner
How to drain water from the machine that stopped working
Use a siphon. Use a piece of garden hose long enough to reach from the bottom of the tub to the floor. Push the hose into the full tub so that the hose fills with water. Pinch one end closed and pull it into a bucket on the floor. Let go the pinch and water will flow into the bucket. Ensure that the other end of the hose stays submerged, and that the bucket is large enough to hold the tub contents.
Jul 19, 2009 | Washing Machines
Hayward Aquabug Above Ground Pool Cleaner Hay500 Logo
843 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
