Question about Nikon Coolpix S1 Digital Camera
How do I change the shutter speed?
I can't quite figure out how to change the shutter speed on this. I need it to be as fast as possible as I'm trying to shoot aquarium fish, who are not very cooperative subjects.
    Brigadier General:
  • 11,967 Answers
You can't change the shutter speed on a point-and-shoot camera. You can change modes and some settings that will force the camera to fire the shutter at faster speeds. For example, if your camera has a "sports" mode, that will fire faster. You can set the ISO to a higher setting to cause the shutter to fire faster.
Posted on May 14, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
That's one of the many problems with compact point&shoot cameras; they simply don't give you enough control overrides when you want them, unlike dSLRs. About the best you can do is to raise the ISO as high as you can and use the Sports mode. You don't want to use the flash, as that's just going to give you the reflection off the glass.
How to chance shutter speed in canon sx 260
For direct control over the shutter speed, set your camera to the Tv (time value) mode. See the "Specific Shutter Speeds (Tv Mode)" section in the user guide (page 140 in my copy).
If you need the user guide, you may download a copy from here.
Dec 06, 2012 | Canon Powershot Sx260 Hs black 12.1mp 20x...
I have a Nikon d200 and need to take sports photos in a basketball court The sport is very fast moving. What should I set the camera to. Lately the photos are dark and or blurry
You want the fastest shutter speed you can get and the largest aperture possible.
If you're close enough and it's allowed, use the flash. The flash will freeze the action. However, it's likely to give you a dark background instead of a blurry background.
If not, use the Aperture Priority mode. Open the lens to its maximum aperture (smallest f/number). This will give you the fastest shutter speed for the existing lighting conditions. The fast shutter speed will freeze the action and the large aperture will blur the background, though the amount of freezing may be limited if the lighting is relatively dark, as in a high school gym.
Be aware that if you're shooting indoors you're going up against the laws of physics. The human eye can adapt much better than any camera. A high school gym will appear light enough once you've been inside for a few minutes, but it is much, much darker than a bright day outdoors.
Apr 28, 2012 | Nikon D200 Digital Camera with 18-200mm...
At the time of photo taken in zoom please instruct me actual shutter speed & exposer in which better photo is taken pranab
Pranab, When using a zoom or telephoto lens, it's just like using a telescope - a little bit of movement in your hand makes the image jump around a lot. If you take a picture under these conditions it is often blurry. There are 5 things to improve the image quality: 1. Use the fastest shutter speed possible. 2. Since a fast shutter speed captures less light, you also need a wider aperture (that's the size of adjustable curtain in the lens known as the f-stop, a smaller f-stop number indicates a wider aperture). The wider aperture allows more light in. 3. Use a tripod. This works for telescopes and cameras. 4. Bright available light. On a sunny day, there is lots of light available, so you can use a fast shutter speed and still get enough light. 5a. On film cameras use "fast film". This film is more sensitive, meaning it requires less light so you can use a faster shutter speed. 5b. On some digital cameras there is Image Stabilization. The image is electronically stabilized - this is like using a tripod to hold the image still, while allowing the camera to move around a little bit. I hope you found this helpful good luck Al K
Jan 12, 2011 | Garden
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
Oct 13, 2010 | Horizon Perfekt Film Camera
How do I change the shutter speed on my Canon Powershot S51S?
It is explained in detail on Pgs. 64 & 65 of the manual.
Feb 21, 2010 | Canon PowerShot S51S Digital Camera
At what setting do I put camera to take fast moveing pic.
Use the sports mode, the one that looks like the stick figure running. If you also need the flash set your camera to "Av" and adjusting the Av (meaning aperture value) to the smallest number possible and turning you flash on.
If this still gives too slow of a shutter speed, try increasing the ISO setting.
Mar 14, 2009 | Canon PowerShot SX10 IS Digital Camera
Blur on fast moving objects
Try lowering the quality of the pictures. It will allow a faster shutter speed since it doesn't need as much data to make the picture. Try throwing a ball into the air and playing with the settings until you can get what you need.
Jan 21, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
Night shots
Hey matty reps,
You are attempting one of the most challenging types of photography there is, because you are combing nighttime photography and action photography. If you want to stop the action you normally would be using the highest shutter speed possible, but since you are trying to take nighttime action photographs I would rely on a flash since the flash duration in essence becomes your shutter speed. I would definitely use a hotshoe mounted flash because the built in flash will most likely not be powerful enough for your needs. I would have the camera set to aperture priority so I could control the depth of field, because the smaller the aperture the larger depth of field you will have and the less likely your subject will be out of focus. If you are attempting natural light nighttime action photography you will definitely need a very fast film speed such as 3200 speed film which will provide significant loss of image quality. You will also need a very fast lens meaning a lens with an aperture of at least f2.8 or larger, and your camera in this scenario should be set to shutter priority so you can set the camera to the fastest shutter speed possible but this will present focusing issues. In both scenarios I would have the AF system set to continuous so the camera doesn't require you to achieve focus to be able to trip the shutter. As in all challenging photography situations more photos are better than less, because you should have more failed photos than successful. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Sport mode settings
Sports photography requires two things: Long zoom, fast shutter speed, and lots of light. Hey! that's three. Ok. So three things.
With your S3IS, you need to use a fast shutter speed to freeze the action (pitchers' arms go pretty fast!) - I suggest trying at 1/500, then 1/1000 second settings. Your camera won't select that automatically, so set the dial to shutter priority, and select that shutter speed. Then, with that shutter speed, you'll likely need to adjust other facets of your exposure to capture enough light. Zoomed in, you'll have an aperture (f/stop) of f/3.5 - or higher (remember: for f/stop, higher numbers = smaller iris, lower number = wider open iris). With your fast shutter speed, you're now fighting for light, so you need the smallest f/stop number you can get - which will be f/2.7 if you're zoomed out, or f/3.5 if you're zoomed in. If at 1/500 shutter and f/3.5 you still have a dark photo, try bumping your ISO setting up to 200 or 400. If you choose 400 or higher you will have a grainy picture. And will need to use a software noise reduction to clean it up.
With the suggestions above, you'll likely not be blurry, but you may be dark. If this is on a bright sunny day, you'll be fine. If this is at a ball park under the lights you may have different results.
Hope this helps...
Oct 17, 2007 | Canon PowerShot S3 IS Digital Camera
Shutter Speed
If its set to Auto it may be that the camera is compensating for low light by slowing the shutter speed. Here is the link to download your cameras driver, manual, and other items.
Jul 23, 2007 | Fuji FinePix S3100 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
479 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
