Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Picture looks like 3D tv without the glasses on. What's up with that?
  • Philips Master
  • 8,457 Answers
Ur tv have a convergence problems,it dead.The convergence board have 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solder,have soldering tools,and solder to solved the convergence problems.U must replaced the 2 STK convergence ICS,and some or all it resitors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Posted on May 14, 2010
  • L. Garcia
    L. Garcia Jan 20, 2011
    Before doing that ^ and spending money $$$, try this out...
    Pull up the menu on your remote and go to the PICTURE settings. Scroll to the bottom and run a converge test. Ex. Converge Red, Multipoint Blue, etc. Align the HUEs with the centered Ts. WARNING: Hues will move when adjusting other HUEs, so you will be repeating yourself over and over again.
    FOR OLD PEOPLE!!!
    If you can't see the Ts when running the test, get someone with 20/20 vision to help you out. JUST KIDDING :P Ha
SOURCE: picture looks like 3D without 3D glasses on???
i had this problem last week. serviceman repaired the convergence issue.
STK392-560 x2 and either fuses or resistors that were blown out
that stk part goes for around 7-10 bucks each on the web
you will need soldering skills to complete the repair.
Posted on Dec 08, 2007
SOURCE: picture is warping and colors
60pp9363h/17 Is my model number.. I'm having the same problem with colors and warpage
Posted on Sep 21, 2008
gtaplytmpt
  • 90 Answers
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Posted on Jan 02, 2009
  • 1030 Answers
SOURCE: pictures look like they are in 3D
FIrst question? if you do not have the convergence option in the customer setup menu then go read the fl231 fuse problem in the tips and tricks section. this is a common problem and a very inexpensive repair
Posted on Apr 24, 2009
localwonder
  • 6784 Answers
SOURCE: picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
Posted on May 18, 2009
When the tv is first turned on the picture is great. After about 5-10 minutes the picture looks like a 3 D movie when you're not wearing the proper glasses. Sometimes turning it off for 10 minutes and...
the 3d effect is caused by a mis alignment of the tree tubes you probably have a broken FRAME holding the tubes in place so that HEAT or VIBRATION can move them and the alingment is off dont forget you have one tube for RED one for GREEN and the other for BLUE if they are not aligned properly they can look like a 3d pcture without 3d glasses ha! sorry for the bad grammer...
Jan 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture looks like 3D without the glasses
This is a convergence prioblem that can be as simple as poor solder connections at the convergence ICs or defective ICs. In any case, to provide details, I will need the model number. Can you please update this and confirm that the model number is: 60PP9202? ALso, please indicate whether or not you wish to attempt the repair and I will provide additional instructions as well.
Thanks,
Dan
Dec 18, 2009 | Philips 60PP9202 60" Rear Projection...
Picture is messed up
need to replace convergence control chips
Jun 12, 2009 | Televison & Video
Poor Picture on HD 52'' Projection RCA TV nearly 4 yrs old
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | RCA HD52W66 Projection Television
Picture looks like 3D without 3D glasses on???
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Jul 20, 2008 | Philips 43PP9202 43" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
227 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
