Question about Schwinn Original Airdyne
Air dyne slips, something between the cranks and the sprocket is slipping, is there a part to tighten or does a part need replacing
    President:
  • Schwinn Master
  • 832 Answers
Their are two sets of chain tensioners ( bracket with a bolt) and one for the fan wheel and one for the pedal sprocket and their is two drive chains depending which one needs tighten. If you have adjusted tension on road bike it is the same concept if you are unsure then a bicycle shop would and should be able to do it for you.
Posted on May 14, 2010
Blades wont enga ge
slack adjuster too tight, bar jammed into sprocket,clutch slipping, chain brake on in off position,chain binding on sprocket or bar, broke end on crank, sprocket slipping on end of crank, a clogged/pinched bar guide,etc.
Sep 02, 2013 | Garden
I have a 1966 mustang 3.3l. i just purchased a new engine & i can't get the harmonic balancer to fit right. it's scrubbing against the timing cover when its tightened down. it seems like there...
66 L6 200. Are the timing marks easy to see? I just did this last week on our 66 block. Just bring it to TDC on #1. Remove the pulley/dampner and the timing cover bolts. Remember to remove the front oil pan bolts to the timing cover.
I use an impact wrench on the cam bolt while holding the crank bolt so I don't slip out of TDC. You'll then have to remove the oil slinger. It just slips off the keyway on the crank snout. Carefully pry the cam sprocket to start wiggling it off the cam. Both the cam and crank sprockets are "keyed".
Get the new sprockets and chain aligned with their marks. Slip the crank sprocket on first until the cam sprocket needs mounted. Just remember to hold the crank, cam sprocket, and chain as an assembly when mounting. Once you get the cam sprocket started, start threading the bolt to hold it in place. Tap light a rubber mallet to seat it further on the end of cam.
I would then remove the cam bolt and coat it lightly with thread-loc and then thread it back in. You don't want it backing out later when your driving down the road. ( don't ask how I know). Remember to put the oil slinger back on.
Your Engine has an oil slinger.
Wayne
Jun 28, 2011 | 1966 Ford Mustang
96 neon starts but when giving gas motor bogs down like its receiving no fuel. Replaced the crank sensor fuel pump and fuel filter
Sounds like the camshaft is out of sync with the crankshaft.
Neons have a real problem with camshaft timing belt sprocket. The pin that aligns it to the camshaft can shear off and then the sprocket can slip so the belt is out of time. If it slips enough, you can bend the valves and then the engine is damaged. It won't necessarily set a code when this happens. If you check the belt timing it will appear to be just fine because the sprocket and crank are still in sync, but the camshaft is out of sync. Pull all the plugs and check compression with a gauge from the auto parts store. If it's low, then that might be it...Normal is 175PSI - 225PSI. OR, your timing belt may have slipped a tooth or two, in which case you can just look through the hole in the timing belt cover with the engine at Top Dead Center. The timing mark should be lined up with the cross hairs on the cover.
May 31, 2011 | 1996 Dodge Neon
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
May 14, 2011 | 1999 Ford Taurus
The chain on the MX500 dirt bike is slipping over the sproket on the back wheel. I've read the posts where the sproket turns but the wheel does not, that is not my issue. I'm thinking I just need to...
Is there a chain adjustment on this bike? It must be very loose to slip over the sprocket. See if there are two bolts that act as jacks to move the rear wheel back away from the drive sprocket. Loosen the locking nuts on each bolt, and tighten both equally until there is only 1/2 inch of play in the middle of the chain, then repost.
Gary
Dec 22, 2010 | Razor MX500 Dirt Rocket
Chain seems to be installed correctly but when I start to cut the chain slips and stops it is properly tightened and pulls easily by hand
You need to inspect the sprocket for wear. Many time the sproket will get a groove worn in the theeth. When you're stopped, and on the normal teeth all is well. If you begin to cut and the chain moves into the goove it's suddenly loose. Replace sprocket and chain and you'll be sure they fit .
Jul 21, 2010 | Garden
Belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Mar 06, 2010 | Exercise & Fitness
Need to change timming belt 1997 geo tracker
TIMING BELT CHANGE You should have some mechanical skills before attempting any engine maintenance! These are basic instructions, and you must knoe what you removed, when, and what order so you can reinstall them in order. First, you have to remove everything in the way! You need to remove the Fan, clutch, and shroud, pump pully & drive belts. Next, you need to remove the Crank Pully:
1. Crank Pully Bolt 2. Crank Pully 3. Center Bolt 4. 5mm Hex drive (used to remove pully bolts) Once the fan stuff, and pully(s) are removed, then you need to remove the Timing Belt cover:
Once the cover is removed, you will need to loosen the adjusting nut and pully bolt on the Belt Tensioner:
A. Adjust Nut B. Pully Bolt C. TENSIONER PULLY Once the the Adjust Nut, and Pully bolt are loose, move the pully as far towards the water pump as possible.
Then, you can slip the timing belt from the sprockets. Check the tensioner for roughness and excess play! DO NOT MOVE THE CAM OR CRANK SPROCKETS! IF you do, then you will have to line up the Crank and Cam for piston number one at Top Dead Center before placing the new timing belt on! Note the timing marks on the crank and camshaft sprockets. IF YOU MUST! Allign the Cam and Crank at piston#1, Top Dead Center before removing the belt. Each sprocket has a small hole, with a line through it, and there is a small groove or "V" it alligns with on the engine. Now, once the timing belt is off, look at your new timing belt. Older belts use the Squared off teeth, while new ones have the rounded teeth. Make sure you have the correct belt for your sprockets! Never reinstall a belt that is in questionable condition. BELT WEAR CONDITIONS
If there are Arrows on the belt, they must be pointing to the RIGHT when you put the new belt on the sprockets. If there isn't one, then paint one on, and place the belt back on the sprockets. The arrow will indicate to a mechanic, this is the way the belt must be put back on (if they replace any cam or crank oil seals). Slip the new belt onto the Crank sprocket. While maintaining tension on the side of the belt opposite the tensioner, slip the belt onto the Camshaft sprocket. Releace the Tensioner adjusting nut to allow spring tension against the belt. Temporarily reinstall the crank pully, taking care to align the notch in the pully with the raised area on the sprocket. Rotate the crank clockwise two complete revolutions. Recheck the alignment of the of the valve timing marks. If they do not align properly, loosen the tensioner, slip the belt off the crank pully, align the timing marks, reinstall the belt, and check alignment again. Tighten the tensioner nut, then the bolt. Reinstall all parts removed, in the opposite order, of course. Start the engine and allow to reach normal operating temp, then road test. THEORETICALLY, you should simply be able to replace the belt with the new one, and go, as long as you did not move any of the sprockets when removing or installing the belt. Most people do it this way, and do not test for alignment before replacing everything. When the belt wears, timing will be off, very little, and this is why you check alignment. The belt may have slipped a tooth, making the timing off. This is why the Cam and Crank sprockets must both align properly. An experienced person will do just that: Replace the belt, and go. It really isn't all that hard. It helps to have a second person around with some experience also.
Nov 11, 2009 | 1997 Geo Tracker 2 Door
91 chevy G20
well not sure exactly why it wont line up use something to turn the crank and cam to appropiate position start sliding crank gear until cam gear is touching then start to push both at same time make sure your crank key and cam pin are bothin place On many OHV pushrod engines, the crankshaft sprocket is installed on the crankshaft nose and the crankshaft is rotated to position piston #1 at TDC. At this point, a mark stamped onto the crankshaft sprocket is pointing directly upward (toward the camshaft).
The camshaft sprocket is then temporarily bolted to the cam and used to rotate the cam until a mark stamped on the cam sprocket is pointing directly downward (toward the crankshaft). The sprocket is then removed from the cam (without allowing the cam to rotate).
The timing chain is looped over the cam gear, the mark on the cam gear is positioned directly downward, and the chain is looped around the crankshaft sprocket. When the cam sprocket is attached to the cam, the timing marks on the crank and cam sprockets should be pointing toward one another.
Feb 10, 2009 | 1992 Chevrolet G20
Mccullough chain saw pm610 chain slips -- maybe clutch issue
have you greased your clutch bearing ever.some times they get dirty and tighten up after running a while.pull your clutch off and clean and grease bearing with a little alex grease,and I mean just a few drops.not meant to have a lot of it,too much will burn the crank shaft and you will have more problems then you started with
Jan 01, 2009 | Garden
Schwinn Original  Airdyne Logo
428 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
