Question about Maytag Neptune FAV6800AW Top Load Washer
Same problem I have the exact same problem with my neptune but lost the manual could you tell me what the dc stands for. THANKS
  • 1 more comment
  • Anonymous Apr 04, 2008
    My Neptune top load washer will not drain. It stops at the spin cycle and gives me a dc error message.
    Maytag repairman says clutch is out over $350.00 to repair. This is a 2 year old machine. Boy did I make a bad choice. My Kenmore masher was still working when I gave it away after 10 years. Maytag should do a recall on this machine.
  • mimikins Apr 04, 2008
    Dear Guest,
    I had your problem and just purchased a new LG which I learned that parts are very durable and not as expensive to replace. The entire control panel is under $100 to replace. The serviceman where I got my LG hasn't seen any come in for repair yet (over 5 years of LG sales) Good luck!
  • julie9757 Apr 11, 2008
    This looks like an ongoing thing!!! My machine is only 1month old. The repairman couldn't figure out what what wrong with it. So he ordered a new circuit board!!!! Now I have no warranty. We paid for a 3 year warranty! What a rip off....
  • 335 Answers
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Posted on Dec 15, 2008
  • 96 Answers
The error code dc means that there is an out of balance condition and the clothing has to be redistributed.
Posted on Apr 04, 2008
  • Abraham Holland Apr 04, 2008
    This is for GUEST who posted comment on Apr 4. The dc error code should not be clutch problem. More likely, if load is not really unbalanced then problem is usually with the Tub Position Sensor at the side of the drum which may have broken loose.
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Error code 57.3???
Fan number 3 (I don't have the manual on me or I would tell you exactly which fan that is) is either dirty or fried. OR it's the DC controller.
A temporary printer error has occured with one of the fans. That's the 57.XX error, the XX stands for which fan.
Clean and/or replace the fan first, and then the DC controller.
Apr 22, 2010 | HP LaserJet 9000n Printer
PD DC STANDS FOR???????????//
it stands for PENTIUM-DUO-DUAL-CORE processor
Jan 29, 2010 | Toshiba Satellite A135-S2386 Notebook
Have a maytag neptune TL water will not drain and on the panel it shows dc
I feel you are experiencing a clutch malfunction if your machine is a FAV6800A or FAV9800A. Can you confirm the machine model number and let me know if you want to try a DIY repair.
You only need basic hand tools and skill sets to repair and I will help you with the fix. See this post for what is involved and this a most recent post of a forum members repair for a dC error code condition in Spin Cycle. I’m an owner with solid repair skill sets of the machine standing by if you want to repair and save your machine and $$$…….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL FAV6800AWW dual turning disks
The center hub on each will unscrew, once you remove this the rotor will come out fairly easy.
Nov 23, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
304 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
