Question about Whirlpool LSR7333 Top Load Washer
We have a whirpool mod#LSR8233JQ. IT stopped agitating in the middle of a load. it will fill but not empty or agitate or spin. the agitator is also locked and will not turn manually.
  • Whirlpool Master
  • 3,051 Answers
Hello there:
Pleasse follow these steps
If your washer doesn't agitate, check these: listed in blue by clicking on them Lid switch Motor coupler Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Clutch it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Drive motor
Posted on May 14, 2010
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer
pull cap off top of agitator remove round cover underneath remove bolt in middle holding agitator down pull agitator up and out pull top portion off by holding bottom half down and pulling top part straight up in center of top part are what are known as agitator dogs either black or tan replace them they are probably worn whirpool part #80040
Aug 28, 2008 | Whirlpool Washing Machines
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
