Question about Kenmore Dryers
I HAVE A 20 YR OLD KENMORE DRYER MODEL 86810100 68101 THERE IS POWER FROM THE OUTLET,IN THE POWER CORD,IT WILL NOT COME ON,NO SOUND FROM THE TIMER.ANY IDEAS?
Buffalo12980
  • 625 Answers
SOURCE: Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Posted on Sep 17, 2007
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
BerkelUSA
  • 24 Answers
SOURCE: Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
SEE VIDEO
http://www.youtube.com/watch?v=tq3k22cqjR8
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Posted on May 20, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
  • 659 Answers
SOURCE: Kenmore Dryer 90 series model number 66912691.
It sounds as though it could be the door switch. Remove it and check for continuity.
Posted on Apr 18, 2009
Kenmore Washer/Dryer Combo Unit Cord Issue
the extra prong is just anothere earth over here we hacve three prongs and 2 prongs its just a better earth thats all and it wontstart a fire ii always change mine i did it to my toaster,microwave,iron,and pc all over 1 yr ago nothing ever happened
Sep 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
I have the same 20 yr old kenmore dryer and it is making alot of noise. can,t find parts for this model . 86810100 68101 please help.
greetings,
here is the model number ...type it in at sears.com and locate your part needed, or tell me and i will look for you...if your pleased with my help. please write a testimonial and thank you
model # 110.86810100
Feb 03, 2011 | Kenmore Dryers
My mother has a Kenmore 500 Gas Dryer at least 15 yr. old. Model 110 660 501. It stopped working and shows no indication there is power. Is there a main fuse or reset switch I can look for? We don't...
it would pay to replace dryer if it is 15 yrs old a newer dryer would be more efficent. Check wires from wall and run them to control panel. Ther should be a relay between power cord and switch
Mar 05, 2010 | Kenmore 72062 Gas Dryer
Dryer will not start have replaced the heating element, door switch and on switch
hi, i recommend inspecting the terminal block that the power cord is connect to on the back side of the dryer. this terminal block may be faulty or, the cord could be lose and not connected properly.kindly, inspect this device that is located on the back side of the dryer for lose connections. if the termainakl block is in good conditon and, the power cord is screwed on tight, thsi iwll confirm timer fialuer.
replace the timer in this case.
May 20, 2009 | Kenmore Dryers
WIRING DIAGRAM
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Jun 07, 2007 | Kenmore 62722 Electric Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
