Question about Maytag Dryers
Overheating dryer - motor replacement???
We have been told that we need to replace the motor in our Maytag SDE4606AYW Clothes Dryer because of the following symptoms:
1) It was exposed to a clogged vent an overheated. The clog has been cleared.
2) The dryer is still overheating. When it gets too hot (usually during only 1 load of clothes), it will shut off for 1.5 to 2 hours until it is completely cooled off and then will start again.
3) The estimated repair is $260. My husband is an HVAC technician, and so I know he could replace the motor, but I want to make sure it is the motor and not another problem before we replace the motor.
Thanks!
    President:
  • 1,218 Answers
Good day,
You said "The dryer is still overheatng". If your not describing the motor but the whole machine then that problem will have to be resolved.
Maytag's build lint up badly in the blower housing area and the duct between it and the filter. Requires disassembling the front of the dryer and cleaning that area as well as determining if the blower wheel is loose on the motor shaft requiring replacing.
If the overheating is the motor itself, then replacing it would be a common item on that brand.
Posted on May 14, 2010
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Maytag Dryer drum not turning properly after cleaning
Make sure the drum belt is positioned properly. You may have disturbed it when you removed the front door panel. It should be a tight fit on the drum. You should see the wear pattern on the drum where the belt was. Check the condition of the belt and make sure it's not cracked or stretched and slipping. Did you disconnect any wires when you opened it? Double check that you didn't rehook the wires wrong and make sure the door sensor switch is in proper position. Hope that helps.
May 14, 2010 | Maytag Dryers
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag sde4606ayw heats up will not tumble when pushing the start button even after replacing a fryed temp. switch.
do you hear the motor trying to run? it could be a belt, or something electrical, door switch could be a option as well
Jun 23, 2009 | Maytag SDE3606A Electric Dryer
Dryer will only dry clothes half way, then when i go to continue drying,dryer will not turn back on until cooled down
Hi, the motor is overheating. i recommend inspecting the motor windings for splits or separation within the strands. make sure all wire connectors to the motor are not corroded or lose. replace the motor if there are signs of windings failures or discolored copper strands.
May 28, 2009 | Maytag Dryers
Maytag SDE4606AYW electric dryer won't start. After drying several loads successfully, I set the timer knob, there was a humming noise and the dryer won't start. The humming noise happens at any timer...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
dghj53
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Elect Dryer SDE4606AYW sounds like belt needs replacing
Go to www.repairclinic.com and enter SDE4606AYW. You will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly.
Jul 01, 2017 | Dryers
Clothes dryer motor overheating
Have you repalced the thermostat?
Apr 28, 2008 | Washing Machines
MAYTAG MODEL MDE9706AYW NEEDS REPAIR
sounds like your motor is overheating, replace motor
Mar 01, 2008 | Dryers
Dryers Logo
502 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
