Question about Dishwashers
My KitckenAid dishwasher will not turn on. All it
My KitchenAid dishwasher will not turn on. All it will do is: the "clean" light blinks. I was told that there is a code I can push and unlock it HELP Garth
  • 523 Answers
Its in a fault code take kick plate off there should be a book there on how to get it out of fault code
Posted on May 14, 2010
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchenaid KUDS01FLBL2 dishwasher will not run
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
Feb 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Jan 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Dishwashers Logo
340 people viewed this question
Top Dishwashers Experts
