Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Mitsubishi Ws -65313 65in
Mitsubishi WS-65313 power light is on but no picture.
  • 116 Answers
I assume, then, that you have sound? When you change volume, do you see the volume display showing? If you see the display, then you have a video problem. If you do not see the display, then you have a high voltage problem. Your picture tubes are not the problem. Please reply and we can go from there.
Posted on Mar 30, 2008
    Genius:
  • 3,422 Answers
The high voltage system has failed. And, maybe the horizontal deflection amplifier as well.
The repair cost will be at least $200 and maybe much more.
The projection tubes could be going as well, although they have a tendency to last a long time. If, however, they are worn down, the replacement cost is very, very expensive.
So the only solution to fix the problem is to get it repaired by a technician.
Goodluck,
Please don't forget to rate the solution.
  • Mitsubishi Master
  • 13,434 Answers
Follow the steps below to reset system defaults to factory settings. . Press the MENU button followed by number buttons , ,and on the remote control. Result: The above steps activate the Reset System Defaults menu screen . Press the ENTER button on the remote control. Result : The settings reset to factory defaults. . Press the HOME or MENU button on the remote control to return to the HOME or MENU screeen. IMPORTANT: This function is not recommended unless it is mandatory to reset system defaults to factory settings. This operation CANNOT be undone and all customs settings will be erased.
If you are unable todo that id suggest you contact Mitsubishi, your dealer, or a local professional.
Main support number 800-332-2119
Support FAX (714) 229-3854
Email support[email protected]
4 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Posted on Jan 13, 2008
ctf1800
  • 4402 Answers
SOURCE: mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 16, 2008
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
Posted on Jun 08, 2008
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
Tip
Mitsubishi WS-73711 Manual Download
Download Mitsubishi WS-73711 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-73711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-73711 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Mitsubishi WS-73711 HDTV operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-73711 VChip Password
Bypass Mitsubishi WS-73711 Front Lock
on May 05, 2010 | Mitsubishi WS-73711 73" Rear Projection...
Power light on
coolant leaks onto signal board frm crt. need to check for corrosive damage on board. to expensive to fix
Jun 13, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
WS-55859 Mitsubishi TV won't turn on
you need the V21/V19 DM repair kit which is available at the following link which has the replacement capacitors and the step by step instructions with pictures.
Oct 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
MITSUBISHI BLINKING GREEN LIGHT
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
343 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
