Question about Polaroid 4226TLMB 42 in. LCD TV
El tv polaroid 4226-tlmb no enciende solo cambia el led de color rojo al azul segun me comentan el daño puede esta en la fuente de poder y no he conseguido el diagrama de la tv o el manual de servicio alguien podria ayudarme gracias
4 Suggested Answers
SOURCE: tengo un problema mi televisor tlx-03210b no cambia de canal
Función de cambio de canal no funciona después de la búsqueda de canales
Posted on Oct 09, 2009
SOURCE: bunas dias , mi problema
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Posted on Dec 27, 2010
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
Como puedo programar mi contro de dish, para poder cambiarle a otro canal, nose que le paso pero no puedo mirar ni el menu de dish y al querer cambiarle de canal se cambia a componente 1 , video 1, video...
Hola Popysateaga, mi nombre es Kim y formo parte del departamento Social Media con DISH. Se que a este punto quizas ya no necesita de nuestra ayuda pero me gustaria contestar su pregunta por si en un futuro llega a necesitar la informacion. Cuando el control no responde con la programacion de DISH pero cambia los canales de la TV significa que el control no esta bajo mode Satellite. Si nota, en la parte arriba del control tiene 4 botones transparentes/blancos usted sabe bajo que modo esta el control al tratar de cambiar canales y el boton de 'TV' se ilumina ya sea rojo o verde. Para poner el control en SAT Mode de nuevo solamente Oprima el boton de SAT localizado en la parte de arriba del control por 3 segundos. Si necesita mas asisencia se puede comunicar conmigo a kimberly.escobar@dish.com
Dec 26, 2012 | DISH Network IR Remote Control
Como Reparo un Plasma Panasonic Viera TH-42PD60X no enciende ni el led de Standby
AMIGO YO TE VENDO LA TARJETA DE PODER PARA QUE NO SUFRAS MAS CON ESE APARATO , O TE COMPRO LA PANTALLA PARA EL MIO QUE ESTA QUEBRADA ,
Compro pantalla para PLASMA PANASONIC TH-42PD60X la mia esta rota, o vendo mi plasma para repuestos , tambien vendo una base para este plasma ya que tengo 2 unidades . gracias interesados escribirme a jaimolb@hotmail.com informes tel 0057 3207250204 colombia
Jan 21, 2012 | Cars & Trucks
El tv th-50px80u enciende un minuto y se apaga y luego da 12 flashes el led donde esta el problema en la fuente o en la placa A
Segun el manual servicio, esta falla se debe a la placa A que esta defectuosa. Antes de reemplazar la placa A, seria necesario de revisar los voltages de la fuente de alimentacion.
Si necesitas el manual de servicio, te lo puedo mandar via email.
Tengo una placa A disponible si estas interesado.
Nov 02, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Tengo un lg42lh55 que enciende la luz en azul y a los 2 minutos pasa a rojo, solo tiene un mes de uso que puede ser?
Puede ser su planta de luz dentro de telvisor esta danado, endonsis usted tiene dos opciones
1. Reparacion con un technico
2. Reparacion con partes www.partstore.com tiene un planta nuevo.
Por Favor deje un voto positive por su repuesta gratuita.
Gracias.
Saludos
Rulds2008
Aug 23, 2011 | LG 42LH55 42 in. HDTV LCD TV
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Bunas dias , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes...
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
Enciende y aparece el logo de la bateria y luego se apaga , y por mas que lo haga cargas mas horas sigue igual . Por favor no se sin ayudar
Si cuando te aparece el logo de la bateria, esta tiene poca carga a pesar de haberla cargado durante horas, entonces podria ser:
1) Un da?o en el cargador (en este caso igual no funcionaria aunque tuvieras la laptop conectada directamente al tomacorriente). 2) Un da?o de la bateria (la bateria no esta tomando la carga). 3) Un da?o en la fuente de poder.
Tambien te recomiendo revisar que los contactos esten limpios: 1) Donde la bateria tiene partes metalicas que hacen contacto con otras partes metalicas de la PC. 2) Donde hacen contacto las partes metalicas del cargador con las partes metalicas de la laptop.
Asi podras saber si tienes que cambiar el cargador, la bateria o si tienes que llevar la PC a un taller a que le revisen la fuente.
Oct 19, 2010 | Computers & Internet
La tarjeta no me pita y no me da video
Una pregunta, cuando esta conectada la fuente de poder y enciendes el ordenador, el ventilador del procesador se mueve? Si no se mueve quiere decir que hay un problema de corriente.
Esto se puede deber a:
1. los cables/la conexión de encendido no esta bien conectada (eg. Los cables que van del gabinete a la placa madre)
2. La fuente de poder esta pagada, desconecta o defectuosa.
3. La placa madre no esta bien aislada. Es decir la placa madre esta siento “tocada” en sitios donde no debe. Eg. las monturas del gabinete están haciendo contacto fuera del las zonas aislada, o un tornillo/tuerca esta tocando la placa madre fuera de sitio.
Suerte,
Ed
Oct 04, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Sep 06, 2006 | Konka K1369U 13" TV
Polaroid 4226TLMB 42 in. LCD TV Logo
793 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
