Question about Dell Dimension 4600 PC Desktop
How do I remove cover to get to memory - Dell Dimension 4600 PC Desktop
  • 721 Answers
You lay the pc on it's side(power side down), press & hold the latch down on the back, then slide the side cover back to remove. In there is the RAM, motherboard,etc. See www.dell.com for additional details. There's a service tag number on the back if you enter that in the drivers & downloads section under support for home users, you will find all that you need, specifically for that machine.
Posted on May 14, 2010
Install memory acer 5000
The memory will more than likely be on the bottom of the laptop. Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory by removing the screw that hold the cover. You should see the memory slots then. If you only see one memory slot or if you see none, then there will probably be memory slots under the keyboard or palmrest area which means you will have to remove them to get to the memory.
May 08, 2012 | Acer Aspire 5003WLMi Notebook
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How to install memory on aspire 4339-2618
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift and remove the memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
Aug 21, 2011 | Computers & Internet
Upgrading the RAM. Can't find where to put it.
The computer has two memory expansion slots—Slot A and
Slot B. You can install one or two memory modules.
1 Shut down your computer completely using the Shut Down
command.
2 Unplug the computer.
CAUTION: Installing a memory module with the computer’s
power on may damage the computer, the module, or both.
3 Close the display panel and remove any cables you may have
connected.
4 Turn the computer upside down.
5 Locate and remove the screws that hold the cover plate in
place, then remove the cover from the bay.
Removing the memory module cover
CAUTION: Static electricity can damage the memory module.
Before you handle the module, touch a grounded metal
surface to discharge any static electricity you may have built
up.
To avoid damaging the memory module, be careful not to
touch its pin connector on the side you insert into the
computer.
6 Remove the new memory module from its antistatic
packaging.
7 Insert the memory module in the slot and gently press it down
into place.
The clips on either side of the module will click to secure the
module.
Inserting the memory module into the slot
8 Replace the cover plate and the screws.
9 Turn the computer over and restart it.
When you turn on the computer, it automatically recognizes
the additional memory.
Removing a memory module
If you need to remove a memory module:
1 Complete steps 1–6 in “Installing a memory module” to shut
down the computer and open the memory module cover.
2 Pull the clips away from the memory module.
The memory module pops partially out of the slot.
Adding memory
Pulling the clips away from the memory module
3 Carefully remove the module from the slot.
4 Replace the cover plate and screws.
May 15, 2009 | Toshiba Satellite Pro 6100 Notebook
Toshiba satellite 310 series (china)
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Aug 16, 2008 | Toshiba Satellite A135-S2276 Notebook
Memory upgrade
most laptops have a cover that is held in by one or more screws on one end .
good luck
Terry
Mar 26, 2008 | Computers & Internet
Removing cover on Acer 5720z to access RAM
Download Aspire 5720 User Guide. Extract the .zip file and open the User Guide Acrobat File.
You can finr info on Installing memory on page 75
ftp://ftp.work.acer-euro.com/notebook/aspire_5720/manual/EN.ZIP
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
The computer automatically detects and reconfigures the total memory size
Regards
Mike
Mar 22, 2008 | Acer Aspire 5610 Notebook
Memory card
1>Open the back cover then remove the memory card.
2>Then take the memory card as well as the back cover
Jan 09, 2008 | Nokia 5300 Grey Cellular Phone
Dell Dimension 4600 PC Desktop Logo
54 people viewed this question
Alun Cox
