Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
Pull cord broke. What kind of gear puller is needed.
Seems a gear puller is needed to get to the pull cord which is broke. What kind do I need?
2 Suggested Answers
stephen_f43949
SOURCE: broke the pull cord. need to know how to take the
bad engineering - the guard is riveted so you need to pull the whole right side of the casing which means removing three brass bolts. BUt then you will find that the steel housing is in the way so you need to remove the engine from the unit - another four tight bolts and a bit of dismantling a few other connections - a lot of work! Then you need to mess with the spring mechanism!!
Posted on Jul 02, 2015
I have a 1999 ford explorer and the whole ignition broke off from the inside. Can that be fixed at home? What do I ask for.
Depending on what is broke, you may have to pull the steering wheel to get access to the components. And to pull the wheel you would need a wheel puller kit and disable the air bag.
Jul 31, 2012 | Cars & Trucks
I need to pull the crank shaft pulley what do i use a gear puller?
Its best to use a puller, you can borrow a set from autozone. Spray penetrating oil and let sit for 30 mins before using a puller!!
Oct 06, 2010 | 1993 Toyota Camry V6
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Harmonic balancer removal. I have nut out but it seems stuck. How do I pull it off. Do I have to remove more than the bolt
Most balancers have a very tight fit to the crank. You will need to use a puller to remove it. If purchasing one dosn't seem economical to you, some auto parts stores rent out specialty tools for free.
Apr 17, 2009 | 1996 Mitsubishi 3000GT
I want to change the mechanical oil seal for crank shaft
you need a gear puller to pull the gear off. but to change the seal for the crankshaft, you only remove the timing gear and change the seal on the cover that you removed. there is nor need to pull the gear itself. if you pull the gear, you still can't change any other bearings or seals without removing the heads and manifold.
Dec 07, 2008 | 2001 Kia Sportage
Pull Cord Broke
the pull cord is same as the regulare pull cord lights.(real cheap one).
bring the fixture to any home center ot hareware store, they should be able to get you what you need.
Nov 12, 2008 | Electrical Supplies
Removeing Jazzy 1170 wheel
Yes, you need a puller:
1 Remove the Nylock nut and washer (3/4 socket)
2 Pull the wheel with a 2 tooth wheel puller
Oct 29, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Steering column spline adapter
You'll need a specialized puller to remove it. You can fabricate one with a pair of vice grips and a regular gear puller.You attatch the gear puller to the back of the adapter and use the vice grips to hold the puller jaws together and slowly pull the adapter off.
Jun 22, 2008 | 1991 Volkswagen Jetta
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
21 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
