I have a Maytag Neptune Stackable Washer/Dryer. Upon researching my problem, I discovered the belt had come off completely and was laying in the bottom of the unit. I put the belt on, and it is slipping off with each rotation. Do I need a new belt (the old one seems to be intact) or could there be another problem beyond the belt?
  • Bridget Burkot May 14, 2010
    perfect...thanks. did that and it is working!
    President:
  • 1,554 Answers
Make sure the belt is tight enough when installed; only a maximum of 1-inch play is allowed when the belt is pushed inside. Check the alignment of the drum and the motor pulleys. The belt has ribs which mate the face of the motor pulley. Misalignment will surely make the belt slip off with each rotation. Specify the exact model number of the washer for specific and accurate parts number, troubleshooting, and repair advice.
Posted on May 14, 2010
I have a maytag neptune washer/dryer stackable. Moved hooked it up dryer works great but washer wont turn on???
Make sure you have power to the outlet, I have seen where a 110 outlet was working on either the top half and not the bottom
Jan 30, 2015 | Maytag Washing Machines
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
