Question about Konica Minolta magicolor 2400 Laser Printer
Menu Is Disabled
I'm trying to access the "Printer" > "Mode Setting" menu for the Minolta Magicolor 2400w, but this menu option is disabled.
The printer is connected and on. There is an error with the toner catridge being empty, but that's why I want to access the "Mode Setting" to set it to not care about that.
Thanks in advance!
Mitch
  • 1 more comment
  • mitchlee83 Mar 30, 2008
    Thank msuhelk. I am the administrator on this PC.. It's a personal computer.
    Hi anon,
    I had already tried this. Did it again. Still no change.
    Thanks for the try, though.
    Mitch
    Reinstalling the printer and driver did not solve it. :(
  • 106 Answers
CHECK IF YOU ARE LOGGING IN AS ADMINISTRATOR OF THE PC, BECAUSE ONLY ADMINISTRATOR HAVE THE RITE TO ACCESS
Posted on Mar 30, 2008
  • SUHEL KHAN
    SUHEL KHAN Mar 30, 2008
    ok if ur the administrator then try reinstall the printer and be carefull to load the correct driver...try this
How do I disable the printer's status monitor. There used to be a box to uncheck after running 'msconfig' that would disable, but I can't remember the name of this check box.
try running a search through the start menu search facility if you are using windows., that might throw up it's location. If not , go into control panel/program management
Printer monitor may be a listed [rpgra,, you can, if it is listed, highlight it and uninstall it
Jun 08, 2015 | Konica Minolta magicolor 2400W
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
Where can I purchase a replacement fuser for konica minolta magicolor 2400w
You could buy it from :-
http://cgi.ebay.com/Konica-Minolta-Magicolor-2400-2400W-2430DL-2450-Fuser_W0QQitemZ180400879568QQcmdZViewItemQQptZPrinter_Accessories?hash=item2a00baf7d0
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 05, 2010 | Konica Minolta magicolor 2400 Laser...
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Trying to select Mode Setting from Printer in the Status Display but the Mode Setting is dimmed ???
Take it to best buy and ask them to help you to fix it and they say it will take a little money to fix to you can fix by your self!!
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 2450 Service menu password
Are you familiar with the printer's PageScopeWeb Connection.
You can access it with your web browser and reset the printer from that page. Instructions for IE are on page 117. The password is SYSADMIN. The printer's ip address is 192.168.1.2 per the manual. unless you have it networked with a different IP.
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2450/rg2450e.pdf
Hope this helps,
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 29, 2008 | Minolta magicolor 2400W Laser Printer
Magicolor no longer grabs thicker papers
I think you need to clean take up roller first, and then set the settings in printer propertis in thick paper.
shold work.
cleaning:
open cover, remove imagine unit, then you can see the take up roller. clean it.
Dec 25, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
248 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
