Question about Craftsman Gas Mini - Tiller/Edger
Tiller is running and in gear but the tines are not spinning.
  • 344 Answers
This Tiller has a cetrifugal clutch, the tines will remain stationary until the engine speeds up, if when using the throttle the tines still do not move then I would suggest trying to adjust the clutch.
Posted on May 14, 2010
  • 2 more comments
  • jltarzan2009 May 14, 2010
    The throttle seems to be tight and working. I was using it and it was working fine when the tines just stopped. I first thought that there was a rock wedged in the tines preventing them from moving. After taking them off and cleaning the debris and placing back on, the tiller is running fine and when i squeeze the throttle it sounds fine, except that the tines still will not spin. Would very much appreciate your input.
  • Tony Groves
    Tony Groves May 14, 2010
    Is the shaft from the engine to the gearbox turning when throttled, if it is then I would think something may have broken in the gearbox assembly.
    With the engine off can you turn the tines with a gloved hand? Do you feel any resistance?
    I cannot with a gloved hand turn the tines at all, they do not move. And I cannot see anything visually at all moving . I had the throttle squeezed and looked at the shaft that conects the engine to the box (is that the gearbox?) in the middle of the tines and did not see anything turning. I may not be following you exactly. Thanks for your help.
  • Tony Groves
    If you cannot move the tines at all then the gearbox may be seized or the end of the drive shaft could be rounded off or the clutch has had it. Sorry it's really difficult to give a proper diagnosis without actually looking at the machine. You could try your nearest Sears Service Centre for repair
    I do hope you manage to find a solution soon, sorry I could not be of any further help.
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
The motor runs but the tines no longer turn
Does the drive shaft turn and the tines just spin around it ? if not then on the drive shaft there is a gear box and you need to open that up (without the machine plugged in) and check to see why the gears aren't meshing properly.
Oct 12, 2013 | Snow Joe Tiller Joe - TJ601E - 9 AMP...
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Apr 06, 2010 | Honda 25cc 4-cycle Mini Tiller
I have power to the tines but the wheels are locked
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
May 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Craftsman Gas Mini - Tiller/Edger Logo
168 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
