Question about Dishwashers
Brand new GE modelGLD4408RWW, runs for avery long time on the normal cycle (3 or 4 hrs.). Did not even flush the detergent out of the cup on the light wash, which ran for about an hour and 30 minutes. The dishes were not clean in either cycle.
  • 523 Answers
Is the water hot enough prime the sink first then start the dish washer/make sure its hooked to hot water i know it sounds dumb but i have ran across that
Posted on May 14, 2010
Steam comes out the grouphead
It should not leak steam out of the grouphead. The three way valve is leaking.
First of all if it is new, get it fixed under warranty. The three way valve is a replaceable item.
On the other hand if you are like me, you can try a back flush with just a tiny bit of coffee machine detergent like "Joe-Glo". The directions might say not to do this but if it is my machine, it's my machine
  1. Get a rubber disk for back flushing. Any place that sells the detergent should sell the disk.
  2. Put the disk in the portafilter and add just a few grains of detergent.
  3. Install the portafilter and "brew" for about 20 seconds, then switch of for 15 seconds or so..
  4. Refill the water reservoir as needed.
  5. Repeat the "brew" cycle until you get "detergent water" in the catch pan. It may take 6 to 8 cycles.
  6. Remove the back flush disk from the portafilter, reinstall, and run a couple of normal 30 second brew cycles to flush detergent out the valve and grouphead.
If this was a coffee maker in service for a while and might have a water scale buildup, I would do the same thing but I would dissolve some citric acid in the water reservoir and descale the boiler, valve, and grouphead at the same time.
Feb 25, 2014 | Rancilio Silvia Espresso Machine
My Smsung dishwasher always has suds in the bottom after cycle has completed
Couple of questions?
1. do you have a water softener?
2. what type of detergent are you using and how much?
3. is the detergent HE rated?
To clear out the suds run a cup of white vinegar with 4 liters of cold water and run a rinse cycle. or just put a cup of white vinegar into the dishwasher and run a normal load with NO SOAP... you need to clear the suds from the system to work properly again. the proper detergent to use in most new dishwashers is powder style that is HE rated. and don't use a lot either.
Sep 17, 2012 | Samsung DMT300RFS Builtin Dishwasher
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Detergent cup lip won't latch even with the cycle indicator dial in the off position.
 The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly.
Please rate my suggestion..
Apr 11, 2009 | GE 24 in. GSD500X Built-in Dishwasher
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Profile SmartDispense clog
I have the same problem and found the below on the GE website. It says to purge the detergent from the Smart Dispense. I am in the process of doing it now...we'll see if it works:
Apr 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dawn detergent in rinse aid dispensor
I did the same. I have run the washer several times but with the rinse aid cup open. Then flushed it by adding water and using a turkey baster to **** the water out. Then used a small amount of liquid fabric softner to reduce the suds. Then flushed it several more times with clear water. The turkey baster will fit into the cup better if you can remove the inside cup cover that dials the amount of dispensing (at least in my brand of dishwasher). I also forced paper towels into the cup opening several times to sop up as much liquid as possible until the indicater light for rinse aid showed empty.  This took some time but by the end of the day, the suds diminished.  Note: I no longer keep Dawn under the sink cabinet where the rinse aid is kept!
Oct 13, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
134 people viewed this question
Top Dishwashers Experts
Owen Barnes
