Question about Sony KDL-52Z5100 LCD TV
I have problems when switching from hdtv to regular tv. Picture will split and have to go back to a non hd channel and back to hd to correct.
  • 178 Answers
Right now the TVs need software update just like the car needs oil change. So you shall do “oil change” first. Click on http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 for Sony software.
Posted on May 15, 2010
Screen splits into 3 separate images not convergence
Make sure you re-adjust convergence in HD and non HD modes if your TV has HD
Mar 30, 2013 | RCA HD52W59 HDTV Projection Television
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
WD-52525 split screen
what are you using as input? On this set only digital channels can be the main picture. You can try the exch button to see if it comes back right also.
Aug 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Picture splits into two halves
Change the box it will solve the problem.
Jun 02, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Hello , I just purchased a 26" Toshiba LCD/HD flat screen TV today. The floor model had the nicest picture at Circut City of the other 26" TVs - but they were hooked up to receive HDTV. When I got it home,...
Yes, the newer flat panel TV's look great with HDTV but amplify the substandard analog TV signals.
I would compare the non HD to VCR quality. If that is what you are seeing then this is normal with non HD broadcasts (typically the channels 1-100).
Hope this helps, please rate my solution.
Jan 11, 2009 | LG 42LG50 42 in. LCD HDTV
Picture Issues
When your watching non HD channels you have to stretch your screen.Your TV has that input option to do so.
May 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Sony KDL-52Z5100 LCD TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
