Question about Metra 993302 Chevy Malibu Installation Kit
Chevy malibu 1999 3.1 scanner code po420 check engine on
After changing egr valve, cleaning the manifold ports, changing gas cap, changing the catalytic converter and oxygen sensor the check engine light is still on. what's next?
    President:
  • 2,309 Answers
Get it scanned before you spend any more, you need to know why the light is on.
Posted on May 14, 2010
What are the probable causes of DTCs P0400, P0171, P0174 y P0302?
DTC code PO400 could be caused by a clogged EGR valve or EGR tube. try cleaning the EGR valve, tube
DTC code PO171 is fuel system too lean bank 1
DTC code PO174 is fuel system too lean Bank 2
Most likely suspects are O2 sensors, But can be caused by vacuum leaks and also can be Mass airflow sensor (MAF) try cleaning with electrical parts cleaner
DTC code PO 302 is a misfire at cylinder # 2
Check spark plugs and wires
Try cleaning the EGR Valve first along with changing the spark plug first, and see if any codes erase, in other words start with the cheaper fixes first, as some problems can be causing the other other codes
Sep 18, 2015 | Cars & Trucks
1998 Ford Escort - P1405 Error code
Follow the link for help with this fault code P1405 Ford DPF EGR Sensor Circuit High Voltage Detected
I suggest you replace the EGR valve position sensor.
Mar 10, 2017 | 1998 Ford Escort
2000 chev malibu is reading a po420
po420--- catalist efficiency below threshold--- possible fix. a po420 means that one or more of the following has happened. the easiest thing to do, is erase code with scanner. and see if it comes back. the engine coolant tempuature sensor may not be working properly, damaged exhaust manifold, or catalytic convertor may be bad. check 02 sensor also behind convertor towards rear. its really hard to say can be anyone off above!! but check 02 sensor first it may be bad.
Dec 02, 2010 | 2000 Chevrolet Malibu
I have a 1997 chevy lumina. i had 2 coded before, po420 and po401. i changed the egr valve, and now the po420 is gone. i just replaced the egr tube, cleared the codes, and now the po401 is back. car sounds...
Well, the po401 is saying is that the egr valve has restricted flow. After changing the egr and the tube, something else is causing the restriction. a more thorough diagnosis is recommended. The po420 code sounds like a possible catalyst failure or an o2 sensor failure.
Oct 16, 2010 | 1997 Chevrolet Lumina
CODE P0401 COMEING UP
I had an OBD II 401 code and fixed it by cleaning out the EGR vacuum line in the intake manifold. I removed teh EGR Valve and the set screw below it. i used a rifle cleaning brush and one length of the rod. Then I replaced teh set screw. I started teh engind and let the vacuum **** some carb cleaner through the front port hole. when it was sucking good I replaced teh EGR valve and reset the codes. That fixed it.8_26_2012_9_39_13_pm.jpg
Feb 12, 2010 | 1999 Isuzu Rodeo
EGR VALVE 1999 MERCURY COUGER
SECTION 303-08: Engine Emission Control 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Exhaust Gas Recirculation (EGR) Valve Removal
  1. Remove the air cleaner outlet tube.
    1. Disconnect the intake air bypass hose.
    1. Disconnect the positive crankcase ventilation hoses.
  1. Disconnect the tube from the exhaust gas recirculation valve.
  1. Remove the exhaust gas recirculation valve.
    • Disconnect the vacuum hose.
Installation
  1. sxu~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: When cleaning the gasket faces, do not allow debris to enter the intake manifold or exhaust gas recirculation valve.
    Clean the gasket faces of the intake manifold and exhaust gas recirculation valve.
  1. Install a new exhaust gas recirculation valve gasket.
  1. Position the EGR valve and install the bolts.
    • Install the vacuum hose.
  1. Connect the EGR tube.
  1. Install the idle air control valve. For additional information, refer to Section 303-14A . For additional information, refer to Section 303-14B .
Sep 15, 2009 | 1999 Mercury Cougar
Po401 and po420 (95 toyota previa Van super charged engine)
Check for air leak into system after MAF.
Check for
vacuum leaks on intake manifold,
the air tube between the air filter.
intake manifold vacuum hose.
clean throttle plate with Berryman carburator cleaner
SEE sample picture HERE
Check for loose or no connected vacuum hose(s).
Take it for a test drive.
Please rate my answer if it's useful to you.
Cheers,
Mustgo
Sep 05, 2009 | 2001 Toyota Tacoma
Same
po113 is--IAT sensor curcuit high input, po403--egr curcuit flow malfunction. IAT is intake air tempurature curcuit, for egr take off and clean carbon build up from inside of engine to egr valve.
Jun 06, 2009 | 1999 Chevrolet Malibu
Metra 993302 Chevy Malibu Installation Kit Logo
496 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
