On its own, the fan went into reverse, turning slowly. Now it will work in both directions, but only at a very slow speed. At its highest speed, it MIGHT be turning at what used to be low speed. At low speed, it now takes over 3 seconds to make a revolution. The light works normally. Model AC5540D. Home Depot SKU 420396. Date 1005. Any suggestions?
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
is the fan single phase or three phase?in other words does the fan connect to 2 or 3 wires?if it connects to 3 wires just change 1 wire to another.
SOURCE: Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
I have a Hampton Bay # 549HRL and the light won't work it dosen't have a normal starter for the light could it be the remote control but the fan and every thing else works fine please help thank you
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
SOURCE: New Hampton Bay ceiling fans spin too slow
Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
SOURCE: Hampton Bay Deluxe Ceiling Fan SKU: 293972
you need a new remote and receiver. mine did the same thing after a few months an then it completely burntout in 2 yrs
Signs of a bad capacitor in a ceiling fan include:
