Question about Amana SXD524VW Side by Side Refrigerator
Help! Water on floor, motor running, all food is barely cool.
A few days ago I noticed a small puddle on the floor near the freezer. Inside the door was an frozen icicle going all the way down the door. I cleaned it all up and thought the door had been left open. Today, more puddle and my ice cube basket is 1/2 full and the ice cubes are melting. The refrigerator part is not cooling and freezer food is thawing out.
Thank you kindly for responding. Anything I can do on my own would be great. I am a single mom on a teacher's salary and was told yesterday that I will soon need a new AC/Heating unit!!!
Thank you, thank you, thank you for any advice!
  • 4 more comments
  • SOSFromVegas Mar 30, 2008
    Thank you so much for your quick reply!
    1. The only frost that I can see is running along some recessed wires located in the lower area of the freezer compartment back section.
    2. The motor sounds normal, although I thought I heard a couple clicks today and wondered where those were coming from. If there are clicks, they are few and far between.
    3. I cannot tell where the metal strip between the doors is located, unless it is white like the rest of the unit. I felt both sides -freezer as well as refrigerator AND the front part and nothing was warm or even room temperature...all cool.
    Just now, I heard the motor turn off, yet the settings are the highest possible AND freezer items are continuing to thaw.
    Any thoughts? This refrigerator is about 8 years young.
    Ooops...I responded to Aborcass BEFORE his email instead of here...so, here goes again:
  • SOSFromVegas Mar 31, 2008
    Hello Aborcass,
    1. Is there something I should know about vacuumming UNDER the refrigerator? I have never done this before.
    2. Should the fan be running all the time or only when the compressor is on?
    Thank you so very much!
    Hello Aborcass,
    I did what you said and voila! All is fine now. Everything is getting super cool and now I can see why! There was so much dust. I even took off the grate over the fan and wiped off the covered up blades. Thanks for the help. Now I can spend $ on things to go inside of the refrigerator instead of someone working on the outside of the refrigerator!
    Very Grateful Vegas Teacher,
    C.
  • Anonymous Apr 25, 2008
    Food in freezer was thawing and refrigerator is cool but not cold. Everything appears to be running. all noises normal. Cleaned lots and lots of hair and dust off the coils. Turned it back on and the lowest part of the freezer around air flow vent froze up. Then used hair dryer to totally thaw the back interior wall of freezer. Now it appears to be getting cold near the bottom but not up high. How long should it take? Doesn't appear to have any air flow to refrigarator. Don't know what else to check
  • Ron Coons
    Ron Coons May 11, 2010
    can be a few issues, here . do you seee any frost building up in front of the lower freezer back wall??? do you hear hte mototr runnnig as normal, or is it constantly clicking on / off?.. feel the metal strip betwwen the doors is it hot to touch , or just room temp ,. it should be room temp if its hot youll need to vacuunn your coils underneath unit as well as check for the fan behind rear of cabinet and see if its turning to cool off compressor.
    President:
  • Amana Master
  • 2,651 Answers
Honestly, heres what id do.
vacuumm under and behind the unit. whilr behind the unit vacuumming check the fan motor next to the compressor, is it turning??? it should be on cooling the compressor as to not overheat. compressor should be warm to hot but not HOT to touch. if after cleanig under you dont get visable results. i would call a local servicer.(dontpull one out of the weekly reader, go on adise of others or perhaps manufactures reccomendation
Posted on Mar 31, 2008
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Every few days I find a small puddle of water near the front left corner under the freezer of my TFH22JR.
Guys, . . . small puddle of water on the FRONT left side?? Y'know, . . under the FREEZER door??!? Maybe check the John Guest quick connect/disconnect fitting at the bottom of the freezer door just behind the front cover. It may not be fully connected, or may have a seal worn-out.
Apr 12, 2014 | GE Refrigerators
Hotpoint ctx18ea fridge not cooling
Kimberley, try this:
First see any sign of ice build up in the freezer.
1. Switch off power from wall outlet.
2. Open the fridge door and freezer door and keep them open for atleast 5-6 hours. Salvage whatever food you can.
3. You may now see a puddle of water under the fridge. Clean the floor and inside of the fridge if water and other fluids visible .
4. Now re-connect power and set the recommended settings- usually at 4. Close doors.
5. Your fridge will be making a humming sound. Let it begin to cool.
Good luck
Apr 05, 2014 | GE Refrigerators
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
I have a Rca Refrigerator...Freezer on top and fridge on lower half...I noticed a puddle of water a couple of months ago on the floor under the fridge on the linoleum floor..I mopped it up and this...
HI. thanks for your question. the problem is with a clogged drain tube, located under the freezer. and goes down to the drain pan. to repair. turn fridge off for at least 24 hrs. use a small plastic hose . go to the drain hose, by the drain pan. push small hose inside the drain tube, up as high as you can. now blow in the tube to clear. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Refrigerators
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
Apr 24, 2007 | Frigidaire FRS23R4A Side by Side...
Amana SXD524VW Side by Side Refrigerator Logo
184 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
