Question about Princeton Digital VL193 19 in. Flat Panel LCD Monitor
19" Princeton Monitor vl193 will not turn on!
This monitor has performed flawlessly for over 10 years. The monitor connector plug was loose and fell out when moving the monitor on my desk. When I plugged the it in while still connected to my computer, the monitor did not power up! It appears as the monitor is not getting power. I check the power cord and the voltage is correct. I connect my wife's monitor and it works using the same connections.
Your help is greatly appreciated!
Best regards,
Barry
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: i have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Testimonial: "thank you the explanation sounds like its right on the mark. Unfortunately, I see these being sold used for under $50 so it is not worthwhile for me to repair as I don't have the expertise and I would think I would be charged at least that by a shop.I was hoping there was a reset button as I think the monitor succumb to an outage. Thanks again. "
  • 125 Answers
SOURCE: stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
Posted on May 04, 2008
  • 5 Answers
SOURCE: Replaced 15'' LCD with 19'' VL193. Can't recover from standy.
Posted on Jun 19, 2009
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
I have had the monitor plugged into my HP laptop. Suddenly, it showed a "Power Saving Mode" message on a blank screen. I have gone through my troubleshooting guide. The screen now shows my background...
Depending on which version of windows you have the directions may be slightly different but in the display settings check to see if it is set to extend the display or to duplicate the display both do very different things. Hopefully adjusting this will correct your issue.
May 31, 2017 | Princeton Digital VL193 19 in. Flat Panel...
I have the princeton VL193 monitor. Its blank, no power light
May 14, 2010 | Princeton Digital VL1916 19" LCD Monitor
I have the VL193 monitor attached to my laptop via blue cable, have checked all connections and display options, resolution, etc. The desktop background photo appears on the monitor but no Windows icons or...
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
Apr 19, 2010 | Princeton Digital VL193 19 in. Flat Panel...
What is an average life for a Princeton Monitor. My seem to last for a little over two years. This is with daily use for eight to ten hours.
Two years is still new. Your monitor should last several years at least. I say should last, but the manufacturer will give you a 1 year warranty. Basically i year is nothing at all. I've had monitors from a variety of manufacturers and all have lasted at least 5 years and most lasting much longer. The monitors I'm referring to were used in a business and were on a minimum of 10 hours per day. I had some Princeton monitors that lasted equally long. You can complain to the manufacturer, but it may not get you any satisfaction.
Mar 17, 2010 | Princeton Digital VL1916 19" LCD Monitor
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Stuck in power save mode
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Jan 26, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital VL193 19 in. Flat Panel LCD Monitor Logo
121 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
