Question about Nokia 6300 Cellular Phone
My nokia 6300
It says file system is busy try again later
  • daniel123456 Apr 03, 2008
    when i try to acces the mail box it says its busy and i cant open the galery it trys to upload but it takes like 2 min and it cant, when i am making a call i can talk for about a minute and then the phone reboots
    Problem Solver:
  • 9 Answers
Sir, reset factory settings of the phone..try to go in your telecommunication their and activate again the MMS..
Posted on Apr 02, 2008
Restart your phone
Posted on Jan 29, 2012
SOURCE:
"file system busy" unable to access memory card in nokia 7210
it is because many files in memory card
first try to connect your memory card to pc then put the files in any folder then re connect to your phone
Jul 26, 2012 | Nokia Cell Phones
My nokia 6300 s music player is not working
In Nokia 3110c and 6300 the problem of Music occurs again and again .There are many possible thing to cause this like using mmc of more than 512mb(1gb is acceptable),transfer of files via bluetooth etc.So, to fix this first download Oxygen Software :: Download and install it to your pc.secondly, open the oxycube interface >>> Hidden files>>> and delete all the dbmusic which is seen inside the folder.Restart the phone and try to start the music player.Good luck.
Dec 18, 2011 | Nokia 6300 Cellular Phone
I connect my nokia 6300 to the Ovi for update. At the end of dowloading, phone just shutdown before it end. Now i can't turn it on. How to solve the problem?
Dear did you know the disadvantage of Nokia PC suit and Ovi suit ?Don't try to do it again because during updating the USB connection frequently lose.Those who advise you to do this have less experience.In my opinion Pheonix is the best is the best solution if we don't want to contact mobile tech.So try this
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 6300 file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
Jul 25, 2011 | Nokia 6300 Cellular Phone
I cant open my music player....
What is the size of the memory card ? if it is more than 512mb this problem will occur again and again.Move all the data from phone to mmc.Restore it and try.if not solved follow the tricks
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Nokia flash file or 6300 file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 14, 2011 | Nokia 6300 Cellular Phone
I lost calculator from my Nokia 6300 phone
www.mobileheart.com/cell.../1129-Nokia-6300-Software.aspx
May 09, 2011 | Nokia 6300 Cell Phone
My nokia 6300 does not receive data via bluetooth it says operation failed but i can send data
nokia 6300 you have to reinstall the bluetooth device in the nokia servies center.and then you can receive dates from other phones.[or] copy the datas to pc and formet the memorycard........
Nov 19, 2010 | Nokia 6300 Cellular Phone
My Nokia 6300 fail to operate after an automatic shut off due to low level of battery. but soon after i recharge my battery and switch it on again, i realised my 6300 was unable to open the contact, sms,...
try to remove your memory card and try to open it again..Most of the time memory card is the cause of hard starting, reason is the the card is not inserted correctly.
just try it, no harm will be done to your unit
Nov 01, 2009 | Nokia 6300 Cellular Phone
My 6300 phone shuts down every time I try to add files.
check the battery 1st proper charged...if still problem then IC of molbile something wrong....sometimes virus is occured.....one try to format please.if still not solve then send me more details...
Aug 19, 2009 | Nokia 6300 Cellular Phone
My nokia 6300 music is not working
this has happened because your music player cannot find the files you want to play.
so to get the music player working again, take out the memory card of your phone and insert it back into the phone.
cheers.
Aug 15, 2009 | Nokia 6300 Cell Phone
Nokia 6300
Try reformatting the memory card with a PC and card reader. This could solve your problem. Make sure you back up important data from your card before doing so.
Mar 13, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
123 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
