Question about Lexmark Wheelwriter 1500 Typewriter
I can not get my margin release to work, what do i do?
  • Lexmark Master
  • 3,594 Answers
Your description is a little lacking. First try puting a little WD40 on the silver shaft that the carrier slides on. It sounds like the carrier is gummed up and reseting the margin.
DickyO
Posted on May 14, 2010
Can not delete tabs and set margins
When using the margin release key just press and release it will not work if you hold it down.
DickyO
Apr 09, 2010 | Nakajima AE-800 Typewriter
The return is stuck on 80 on the guide. I cannot
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
Mar 18, 2010 | Nakajima AE-710 Typewriter
The margin release is not working on ML 100 typewriter
You must have the carrier at the exact margin in order to release it. To release the left margin, hit the RETURN key, then MODE with Mrel. For the right margin Depress TAB or SPACEBAR to get to the margin and then MODE and MREL keys. NOTE: Make sure the typewriter is not in L/L MODE.
Dec 23, 2009 | Brother Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 05, 2009 | Office Equipment & Supplies
Reset margins
Above the number keys are words in green or blue the margin release, L. mar. and R. mar. are there return to the L. margin, press the alt key with the mar. rel. release them, backspace to the location for the L. mzr press alt and L. margin key, R. margin works the same way.
DickyO
Mar 18, 2009 | Brother SX-4000 Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
Margin Release
Try holding down on the MR (margin release) key and turn on. Machine will print a few lines with all the letters. Turn off and then on and try. Also make sure someone has not switched the key tops for left marging and right margin, I have seen this "joke" played on people. Can you set either margins?
Aug 13, 2008 | Nakajima AE-710 Typewriter
CAN'T GET THE MARGINS TO RELEASE
Return to L. mar. touch and release margin rel. key backspace to desired location press l. mar key
DickyO
Mar 19, 2008 | Nakajima AE-740 Typewriter
Right margin won't release
Try touching the margin release key then the space bar to pass the margin then reset it in a new location with the right margin set key
Oct 16, 2007 | Brother GX-6750 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
