Question about Intel Motherboard
GA-EP35-DS3R won't POST - Core Duo E8400 / 2GB Crucial 8500 DDR2
On power up, the CPU fan spins up for app. 1 sec; then all powers down. Repeats every 5-7 secs or so until powered off. Tried moving the
memory and tried just one stick. No difference. Tried a new 24 pin ATX
P/S (500 watt antec); no change. Any ideas of what else to try? Is it
likely that the board is DOA?
  • Chynnae Mar 31, 2008
    I have a similar problem but my components are slightly different
    Case: Antec P182
    Mobo: GIGABYTE GA-P35-DS3L
    PSU: Corsair 520HX
    CPU: Intel E6850
    GPU: EVGA 8800GTS 512MB (G92)
    Hard Drive: WD Raptor X 150GB
    Ram: Corsair 4GB PC2-6400 C4
I took my computer to a professional store, and they said that my motherboard, power supply & video card needed replacing. All my components were brand new! I suspect what happened is that my power supply fried the motherboard and video card.
This is not something I could have figured out on my own. To do this, you would need a spare system and swap parts in and out one at a time to determine which piece wasn't working.
Posted on Apr 10, 2008
  • 152 Answers
Remove your cpu core voltage connector and power on if power on still so 100% your vrm circuit mosfet sort
Posted on Mar 31, 2008
I have this same exact problem on two of 4 Gigabyte motherboards I purchased and built systems for the past few days. One works fine. One, I have not completed yet. The other two worked for awhile, then during a reboot they both failed to start back up. When powered up, the lights and fans come on for one second then shut off. 5 seconds later it repeats until I either cut the power or hold the power button down for 10 seconds. I've tried everything I could think of. Tried different ram, single ram sticks in one slot, older Pentium D cpu's, different power supplies that I know work, tried pulling every component out (all I had was a hard drive and a video card), and tried resetting the cmos. Nothing works. What would fry the motherboard like that?
SOURCE:
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
GA-MA790GP-DS4H doesn't boot. It gives 14 short
Hello my friend,
There is no way to have 15 beeps error especially short ones so
First try to count the beeps and if are long or short
Jan 29, 2010 | Gigabyte Computers & Internet
GA-EP35-DS4 motherboard does not load
is it in warranty..?? if not..
do it if u r a professional..
check the following:
1) the cmos battery (above +3v)..replace with a standby n see..
2) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
3) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
4) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
5) ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
..plz give higher priority to step3 & 4 (as listed above) CAREFULLY..
immediately contact ur system admin/vendor....
Nov 07, 2009 | Gigabyte GA-EP35-DS4, LGA775, Intel P35,...
My pc shuts down by itself
you need to replace the RAM ...
Apr 23, 2009 | Computers & Internet
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : [email protected]
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
My Computer is Keep Restarting
The Motherboard is going bad if it restarts on it's own. I suggest you try a different board.
Jun 12, 2008 | Intel Motherboard
Fried Motherboard
if you are sure the entire thing is fried, and you have to be sure, i would reccommend a Gigabyte GA-EP35-DS3R motherboard, if your processor is an intel, it does down to pentium d, and ddr2 ram. i bought one of these and i can still upgrade to core 2 quad if i wanted. (does not support AMD processors,or ddr1 ram). will work for a long time, 5 year warranty at some places
Mar 09, 2008 | Intel Motherboard
GA-EP35C-DS3R random reboots
Hi Buzznode,
First things first - once you have all the components properly seated (sometimes if a RAM chip or CPU heatsink/fan isn't quite right it'll cause those problems) clear the CMOS entirely. There should be a jumper somewhere near the CMOS battery - move it from the 1-2 seating to the 2-3 (with the system powered down) and count to ten. Move it back over and then try booting up again. If the problem continues, swap the memory chips. Otherwise repost once you've tried the recommendation.
Ben
Mar 07, 2008 | Intel Motherboard
Intel Motherboard Logo
345 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
