Have a savin 9113z copier that is flashing e 54. tried solution posted on jan 04, 2010 but still not working
  • 23 Answers
This is a tricky adjustment. You have to get into the service mode and there is an adjustment on the main board. I hope you have not tweaked the adjustment pot on the board, if so this may not help. Ok here is what you can try. First remove the cleaning unit-its on the left side when you open the front door, its a black box with a cleaning blade, one screw holds the unit in place .Dump the old toner out. Now the sensor that may be dirty is along the rail that the waste toner box slides in on (bottom right rail ) . With a flash light you should be able to see the sensor close to the drum about hafe way back along this rail. Do all of this with the machine opened up using the lever inside the front door at the right. Becarfull and DO NOT TOUCH THE DRUM. With a can of compressed air with the little pin point thing to spray the air out with attached now blow the sensor off. Put the cleaning unit back in and turn on the copier. If the message comes back call your local dealer. Good Luck and be careful around the drum.
Posted on May 15, 2010
I have a PZ6114 vivotek cam and has a flash corrupt problem, the cam turns on, get ip but never keeps the config data, also report a big config.ini file ftp> dir 200 PORT command successful 150...
What I could recon from your question is that your webcam driver is not installed in your PC.
Please be informed that any Driver software depends upon the hardware make and Operating System. So, you need to know all these information's to do get going.
Please find the Driver software's of your webcam inside the installation disk provided with the System at the time of purchase. In case if you do not posses the same then you need to download the driver software from the web. As you have not mentioned your \ Operating System you are using, I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the Webcam.
http://www.vivotek.com/support/faq.php
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Webcam Model number and the OS that you are using.
After you have downloaded the driver, to install just plug in the webcam on to your PC and then Double click on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
Jul 09, 2011 | Vivotek FD6112V Webcam
I have a savin 9113Z that is flashing a 54 error code.what is wrong?
Chekc or replace the fuser unit thermoswitch and thermistors.
May 16, 2010 | Office Equipment & Supplies
I have a Savin 9113Z copier that is giving me a error code of 54. Any advice
Hello sir; You do need to reset this error code, procedure as follow;
press 71,hold down "clear/stop"key, until you see the "." in the upper left cornor of the display, then release, after that you press "clear/stop" key again then press lighter key, the 5 will now flash on the display, now enter 97 press start, turn machine off and back on , machine should be running.
Jan 04, 2010 | Savin Office Equipment & Supplies
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
Unstable internet connection with a DSL2640U
I've heard that the issue can be resolved with a firmware update.
Go here to get it.
http://www.dlink.co.za/dsl-2640u_t.php
Jul 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Jun 02, 2009 | Ricoh Aficio 450 Copier
159 people viewed this question
k24674
jasbo
jasbo
