Question about Frigidaire FEQ332E Electric Dryer
Hi, dryer wont turn on. has power but wont do
Hi, dryer wont turn on. has power but wont do anything.
  • 547 Answers
There are 2 fuses located one on the heater side at the top and the other at the exaust side at the bottom if you hard wire the one then the other you can figar out witch one it is if none work hard wire both then replace them.
Posted on Oct 17, 2013
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryerHi,  dryer wont turn on.  has power but wont do - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turnHi, dryer wont turn on. has power but wont do - 2_bing.gif />
Dryer2Hi,  dryer wont turn on.  has power but wont do - 2_bing.gif class= Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 15, 2010
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
One day it worked and the next day it wont turn on. it has power but wont start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Dryers
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
Roper,model# rex5634kq1 Just quit working. wont turn on or anything
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Roper Dryers
Dryer stopped running, wont turn on, i have power to motor, i hooked a meter to the two blue wires on moter and pushed the start button, power is there, but i assume the motor burned up, not 100% sure but...
Dryer Repair ? The dryer will not start
heatman101
Aug 30, 2010 | Whirlpool LER5636P Electric Dryer
Basment flooded was under water part way now wont do anything when you try to turn on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 12, 2010 | Roper REX4634KQ Electric Dryer
GE dryer makes loud huming sound wont start
There can be many reasons why your dryer2_bing.gif will not turn...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
May 25, 2010 | Dryers
Have A dryer that has power but wont turn on. Light inside is on but wont do anything else
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Oct 15, 2009 | Dryers
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Dryer wont turn on
turn your breaker off the on
Dec 31, 2007 | Fisher and Paykel DE08 Gas Dryer
Frigidaire FEQ332E Electric Dryer Logo
516 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
