Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet We can not get the new door seal to stay put...it keeps coming off.
  • 770 Answers
What is your email i will send you the service manual
Posted on Apr 01, 2008
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
What do I do when the big spring that is seemingly behind the rubber bladder of the the door opeing keeps popping out on my Whirlpool washer Duet?
that spring is for the door water seal if it "pops" off when you have a load of washing being washed you will flood your kitchen floor with water,,,fit a new door seal and a new spring fast!
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Water leak at door
Check carefully for a small tear in the boot or it came loose from the frame.
Eric
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front load washer keeps leaking from the door im only using alittle soap and its new any suggestions the repair man just keeps saying im using to much soap but im using under the recommended amount
look at the door seal, are the seal look exactly the same all around? if not, have the repairman change the door seal. if it is, use the method all car salesman use. (old time). put a dollar bill against the door and close it. now try to pull the dollar bill out. you should not be able to remove the dollar bill. if you can then the door is whopped. may have to change the door.
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leak at door but seems to come from door itself.
no seal in outer door, but that's what you need outer door frame about 300.00 , labor 152.00 buy service smart agreement from sears it will cover parts put to 500.00 it will fix it "less soap plz"
Nov 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool door pin location
No, unfortunately the door latch assy. comes as a complete unit. Part# 8182634. This # is for the entire door latch mechanism, not just the pin and lists for ~$45.00. Easy repair... open the door. At the 6 o'clock position of the door seal, begin removing the seal clamp with a small screwdriver by inserting it between the spring and the seal. Then peel the seal back (at the 3 o'clock position) to gain access to the latch assy. Remove the 3 screws holding the latch in place and pull gently out. Remove the wire harness. Install the new latch and rebuild. (make sure you position the seal clamp the same way it came off... the spring at the 6 o'clock position.) Install time= ~15 minutes. Job done! and well worth the 50 bucks!
Aug 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
