I have a whirlpool duet sport wfw8300sw01 error code F- how do i fix this myself
    Top Expert:
  • Washing Mach... Master
  • 76,649 Answers
Please clarify the error code, F what?
Posted on May 14, 2010
  • 2 more comments
  • themedskers May 14, 2010
    it is just F- I know with my old duet it was a 2 digit code, but what is happening is cold water will not flow in, I hear the buzzing then the error code. I purchased this washer used from Rent a Center for $400 and it has a warranty through them. rather than replacing it using a sub until they fix mine I wondered if I can fix it myself
  • yadayada
    yadayada May 14, 2010
    IT WILL NOT FILL WITH HOT OR COLD WATER SELECTED? IF NOT U MAY HAVE A DEFECTIVE TIMER CONTROL, IT IS A COMMON FAILURE, THE PART IS ABOUT $160.00
    I only have an F- not two letters like on my old Duet. I can't use cold water. I hear the buzzing then no cold water I wanted to know how to fix it myself since I purchased it used
  • yadayada
    BELOW IS A WEB LINK TO YOUR MACHINES SERVICE AND REPAIR MANUAL IN PDF FILE FORMAT
    https://secured.whirlpool.com/Service/Sr...$FILE/Duet%20Job%20Aid.pdf
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Need error messages defined SD and F1
the "sd" is a code for a suds lock. if you have the wrong soap, needs to be the HE type, or too much soap it will suds inside and cause this failure, choose the rinse and spin cycle to remove any soap suds.
the f1 code is an internal failure in the computer and may need to be reset by just unplugging the unit for a few minutes and the trying it again.
i hope you can just clear the suds and it will be ok, if not then the main control board will need to be replaced.
if your unit is not too old then call whirlpool and see if they will help you with the cost of replacing the board.
Jan 31, 2009 | Washing Machines
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
