Question about Electric Lawn Mower
My electric lawn motor will not start after being turned off normally. There is power to the mower. Is there some kind of fuze on board? Is the mower dead? It is manufactured by Yard Machines.
    Genius:
  • 1,354 Answers
Hi
thank you for using Fixya
i have seen your isuue i thing you have problem with power suply
frist chack your power cable then cahck your power conaction
then try it will work hope fully
Posted on May 14, 2010
  • jimiritem May 14, 2010
    I have checked the power cord by attaching a lamp to the end where the mower goes and the lamp lit, so the problem must be in the mower itself.
  • if your getting power then there is some technicale problem better go to technition
    he will give you the solution
    sorry for inconvention
Can i fix small electric motor
Most electric motor problems are caused by the bearings failing. Before that happens it may get very stiff but stil turn. With the power off, and the blade still attached, try turning the blade at least half a turn. Is that possible? Any noises as you turn? Is it very stiff or fairly free? If you turn it several times you may find that putting it upright and connecting the power it may start turning again.
Let me know what you find.
Jul 04, 2014 | Electric Lawn Mower
It starts,but halve the power than normal
turn it upside down clean all the dried grass away from the holes around cutter shaft, apply a few drops of 3 in 1 or similar oil to shaft
bearing. Clean all dried grass from holes around top of motor casing
re try machine if it is not faster than before motor brushes are worn
and its time to buy a new one
Jan 17, 2014 | Electric Lawn Mower
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
I was in the process of ripping a board and the motor just stopped while cutting the board as if it was jammed. I removed the board hit the reset button and it still did not work. 113-197610 radial arm...
Sounds like the motor has burnt out, you can try to turn the motor manually after you unplug it, if it won't turn or is hard to turn, you will need to replace the motor
Oct 16, 2013 | Electric Lawn Mower
Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
Remove blade from sears 4 hp electric lawn mower
Most all electric mowers are held on by a LEFT HAND THREAD bolt because of the direction the motor turns. Try to turn the bolt in what would normally be the tightening direction
Sep 09, 2009 | Craftsman Garden
My Wolf electric lawn mower will start but cuts out after 30 seconds then after some minutes will start aagin. Have checked power is getting to motor and is fine. Also put multimeter across motor &...
There may be a fault contact due to vibration check all the electrical wires and contacts if they are very well connected check corrosion point at contacts, use wd40 spray oil in the motor and contacts, there may be a fault in the carbon contacts to the rotor.
Hope it help
Jun 25, 2009 | Electric Lawn Mower
Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Jun 14, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Electric lawn mower will not start
check the speed controller and also check the terminals on the motor.
May 21, 2009 | Electric Lawn Mower
Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Electric Lawn Mower Logo
376 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
