Question about Refrigerators
Circuit diagram for WEstinghouse Virtuoso Side by Side Fridge
Hi our fridge is tripping the circuit and we think it's happening when it goes into defrost mode. WE are after a diagram of the electrical circuit. Do you know where we could find one?
Thanks
    Scholar:
  • 178 Answers
It helps us to help you if we have a model number to work with. I have a site called www.mymarcone.com that if I have a model number, I can look up virtually ANY appliance diagram. Please post on this again with a model number and I will do my best to help you.
Posted on Mar 30, 2008
2 Suggested Answers
  • 178 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
If it is kicking the circuit breaker out in defrost mode, then the defrost timer is faulty. It would be best to just replace the timer instead of checking the wiring schematic. Look at www.partstoday.com for helpful illustrations on parts and identifying pictures.
Westinghouse RPG423GR fridge is freezing and tripping circuit is this the thermostat? Is a wiring diagram available?
The compressor windings shorting out are usually what trips the breaker. Someone will need to test the windings and if they are defective it will be best to replace the fridge
APPLIANCE 911
Jan 10, 2016 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Hello, I'm chasing a fault on my westinghouse RJ442K-R*6, fridge. It's tripping the earth leakage. The compressor meggers fine, but the brown wire going up to the thermostat direction is down to earth. It...
Why not remove the ground fault circuit interruptor (GFCI)? Condensed moisture in the fridge evaporator area, along with defrost circuit and other electrical may be the cause of the ground fault.
Oct 30, 2017 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Power failure
Code actually calls for the refrigerator to be on a separate circuit for this reason. you may have a refrgerator that may have a higher voltage spike at compressor start up and that is causing the trip. You can try upgrading your GFCI to a 20amp (most are 15amp). Although you may have to replace with a standard outlet if the problem does not subside.
Jul 28, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
734 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
