Question about Kenmore Elite HE4 Electric Dryer
My washing machine fill up but no longer starts unles you bang on the lid. Now it won't even work doing that.
  • 11,896 Answers
The lid switch is likely faulty and will need to be replaced. You can get one from partselect website or repairclinic website. I recommend partselect. If you desire, you can test the switch with an ohmmeter in ohm position. Should have infiinity reading with lid closed and no reading while open.
Posted on May 14, 2010
Water will not fill my washer machine
  1. what worked for me was banging on the top right where the control are - there is a chip in there and every now and then that will happen to mine and I bang on it a few times with the palm of my hand.
Jun 26, 2014 | Whirlpool Cabrio WTW5600XW Top Load Washer
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Wtw5200VQ2
have you checked the lid safety switch under the top that opens and stops the machine when you open the lid? if these get bad they wont work even if the lid is down,you can open control panel and by-pass this switch for testing
May 11, 2012 | Whirlpool Washing Machines
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
The washer turns on and fills up but then stops. If you bang the lid a few times it will usually continue on the cycle and be fine. You have to repeat the lid banging for every load though. The lid...
Sounds like the switch that the lid presses is either broken or has been knocked loose.
Or the little plastic or metal "switch actuator" (the little poker) that presses the switch has broken.
I believe the washer thinks the lid is open because it will fill up but wont't wash until it knows the lid is shut.
Jul 18, 2011 | Whirlpool Washing Machines
Maytag Atlantis MAV6200 fills but doesn't do anything afterwards
If nothing turns on than your Lid Switch is probably it.It is the first most common fix on this model. Please Rate This !!!
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
