Question about Linksys Wireless-G WRT54GS Router (e125894)
My laptop cannot connect by wireless to linksysWRT54G
My laptop can detect the wireless signal from linksys WRT54G router but connectivity is not available. How to connect?
  • Linksys Master
  • 6,487 Answers
You can follow the steps from my tips in order for you to correct the problem that you have, check this link for the step by step procedure to fix the problem.
http://www.fixya.com/support/r3791502-resolve_intermittent_wireless_connection
Posted on May 14, 2010
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Tried to reset password..seemed easy enough,done.. reset router name easy, reset password easy. reset ssid easy..in fact my password was the same for everything to make things easy. Now i go downstairs...
Router paswords are chase and space senitive, Reset the router and choose a different password that not been used. then repower the router, and connect using the new password.
Oct 24, 2010 | Linksys Wireless-G WRT54G Router
No wireless detect connection
Hi
Note all changes to be made from wired computer only . Any computer that is phisically connected to the router.
Open the router setup page by typing in your default gateway address( router address) on the web browser
You can get it by
Start -> run -> cmd -> ipconfig
You will see the router setup page opening up
Check what it says . IF on the top it says Internet Status :: Connected then
1. Under wireless you'll see channell and ssid
2. Change channell to 6 or 11 .That gives you the best wireless signal strength . This is the most probable cause .
If you want you can also change the
3. Check your security key
4. And apply changes
5. Now on your wireless laptop go to Control panel ->Network connections -> wireless network connections -> right click -> deleate preffered networks -> refresh netweork list
6. You will find your network there select and connect.
Works great
If Ip status : says not connected
1. restore factory default
2. reconfigure router
3. reconnect
This shoud help and please let me know .
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Linksys router when cabled, doesn't work wireless to laptop
can it detect the wireless signal?
did you load the drivers for wireless card in laptop?
check the device manager for any ! or ? in it those need attentio
if you can detect the wireless network then you need to set the wepkey if its enabled. if its not and you have a signal then just click on connect in the wireless network manager
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
My lap top connecting to my wireless system.
Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
Try configuring or verifying the wireless settings of the router first by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4585&p_created=1165894972&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aXJlbGVzcyBzZWN1cml0eQ**&p_li=&p_topview=1
After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_created=1160185039&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAyNSZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb25uZWN0aW5n&p_li=&p_topview=1
If you cannot still connect wirelessly, let me know of the following:
- model number of the router
- operating system of the computer
- wireless adapter installed on the computer (built in or external)
- brand of wireless adapter installed
- wireless settings of the router (SSID, wireless security)
May 13, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
