Monitor displays for maybe one second before going black.
Check RAM
Posted on Mar 30, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Samsung SyncMaster 174v will display image for 2 seconds then go black. When I turn monitor off and then on again, it displays image with normal brightness for 2 seconds and then goes black. When I plug...
Hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 10, 2010 | Computers & Internet
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Monitor connects and displays for 2 seconds, then blacks out.
I would suspect an electrical component is failing. Try your monitor on another computer and see if it does the same thing. If it does, the monitor is failing. Also/Or try another monitor on your computer. If the new monitor does the same as the old monitor, then maybe the video card in your computer is failing. Try a new video card. Keep trying different component combinations until you decide what has to be failing.
May 30, 2009 | KDS Computers & Internet
Monitor screen goes out (black) 2 seconds after turning on
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Jan 16, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
