Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher and paykel water leak
Initailly my dishwasher came up with F1 code,
I cleaned all contacts and emptied it
Upon starting a cycle, i left the front cover off, watched it fill up with water (even when i open the door, is this normal?)
There are 2 holes (1 on either side) by the front door seals, that the water leaks through,
I believe the washer is overfilling???
Any advise would be muchly appreciated
fisher and paykel nautilus
  • 30 Answers
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Posted on Sep 04, 2008
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Oct 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Washing Machines Logo
665 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
