Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
Bad pressure switch
I have a Cambell Hausfeld Pressure washer PW181000AV .
I can bypass this switch and the unit will run. I replaced the springs inside the unit with the closest spring i could find. ( the original springs were broken). When you run the unit it will run until the switch acuates and then will not reset.
    Problem Solver:
  • 4 Answers
Do not use different springs
Posted on May 14, 2010
What do i do to get it to start working?
i assume you put gas and pulled the rope an its running
and have water connected and running
if all is running an water is on an the pumps not pulling then the pump is frozen
May 03, 2015 | Garden
I have a gas powered 2200 PSI Cambell Hausfeld pressure washer when i try use it the pressure pulses up an down the complete time you hold the trigger down an ideal what i should look for Thinks
Quite often this can be caused by low water supply. Check the filter that the supply hose plugs in to and make sure your water supply has plenty of pressure and volume. There will be a water volume rating in litres per min (lt/min) or (gal/hr) depending on what part of the world you live in. You need to have at least that amount plus half again feeding the machine under a reasonable pressure 6ft/lb Gravity fed from a tank won't cut it. If it is vibrating and hardly working there is grit stuck under one of the valves which isn't a biggie but if you don't know how to disassemble the pump valves take it to someone who does as there are small parts like springs etc that are easily lost. It won't break the bank to get someone to repair it. Cheers. Hope this helps.
Jun 27, 2014 | Campbell Hausfeld Garden
I have a campbell hausfeld 2450 pressure washer with water coming out of a brass hose nozzel right next to where you screw the high pressure to the pump as soon as you turn the water on from the house,...
this is called the chemical injector which enables you to insert the hose for you to dispense the soap and or chemical by utilizing a soap nozzle .apparently inside this barb you will find a ball a spring and a o-ring,find the replacement parts or kit from its manufacturer.finding a plug to replace it is not recommended due to the fact that the pitch of thread is hard to find.replace asap this unit relies on trap pressure to unload.
Aug 04, 2013 | Campbell Hausfeld Garden
I have a cambell hausfeld 5.5 horsepower pressure washer that leaks a milky substance from the bottom of the motor. Why is that?
The "milky solution" could be oil that's been contaminated with water. You may have a bad seal within the pump, allowing water to mix with the oil...
Jul 01, 2013 | Garden
Cambell Hausfeld model wl506201aj compressor Hums when switched on
This could be caused by one of two things:
- a stuck or broke tank check valve. This would be evident if the compressor starts up when there is no pressure in the tanks but only hums when the tank pressure is up. Some valves can be cleaned and will work for a while but they usually have to be replaced.
- motor start capacitor. If the capacitor is bad it won't get the motor spinning, with or without pressure in the tanks. You can test it by taking the shroud off the pump and carefully bumping the motor to get it turning. Be careful, it may run up to full speed right away. If it runs replace the capacitor, if not you may have a burnt or shorted motor.
Apr 11, 2012 | Campbell Hausfeld Air Compressor Check...
Breaker keeps popping when I start unit
If the unit isn't even starting up and running you have an internal motor problem, either you have wires that are crossed, switch that is bad or capacitor that is bad. Most of the time on a unit like this it is not worth going to and repairing, for the price that it cost for the parts you are better off just purchasing a new machine.
Oct 31, 2010 | Campbell Hausfeld 1,350 Psi Electric...
Will only get to 60 psi what do I need
Most compressors are operated with a shutoff pressure switch to stop it when it gets up to pressure. They are usually adjustable with a screw under the cover. Unplug the unit, remove the pressure switch cover, and look for a screw or bolt that has a spring under the head and is attached to the contact unit. The more pressure you put on the spring, the higher the air pressure.
Sep 24, 2010 | Campbell Hausfeld Air Tools & Compressors
C.Hausfeld HLseries compressor pressure cut in setting
Hello. The answer is yes. Let me warn you to make only small adjustments at a time and be sure to relock the two screws using some one minute clear epoxy.
Jul 24, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
350 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
