Question about GE Refrigerators
My GE tfx20jr refrigerator is leaking water from some where, checked the bottom in the front, but there is no pan to pull out. Any suggestions? Thanks.
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
SOURCE: Water Leaking from the bottom of the Refrigerator
Mine was doing the same thing. Turns out the water supply line was broken just above the bottom hinge for the door. I had to remove the shelves on the freezer door by removing the screws around the door behind the seal and then spliced the line up by the dispenser and behind the grille at the bottom. I used 1/4" supply line that was left over from hooking up the supply line and two 1/4" to 5/16" adapters from lowes. A fisch tape makes it easier to run the new piece through the door but the fix was pretty simple overall.
Posted on Feb 27, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
MNTECH
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
  • 113 Answers
SOURCE: Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Posted on Apr 27, 2009
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
Leaking water from the front right side.
check drain tube and drain pan on bottom of unit most likely plugged drain or water line going up door is leaking
Dec 21, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Leaking water from bottom of fridge. It is a GE peofile with ice maker, water. appears 2 be from one of those lines
Hi kadoran144,
The leaking water from the bottom of your fridge is often caused by the drain pan. There are some ways on how to correct this issue, either you clean the pan and reposition the tray. In addition, here are some tips that you can apply to solve this problem. Please follow the steps below.
Before conducting any repair, please remember your safety. Unplug the machine or shut off the power at the breaker panel to avoid any electric shock.
1. Remove the drain pan and clean it with a warm soapy water or water and baking soda.
--> the drain pan is located at the bottom of the refrigerator behind the front grill.
--> Please remove the grill which snaps into place. Hold the drain pan while pulling slightly upward and forward.
2. If you noticed that the pan is too closed to the compressor please reposition the tray.
3. You may also try to check water invelt valve. It is located behind the refrigerator. Look for a water supply line coming into the valve and turn it off at the source. Now disconnect the supply line. It has screws so you need to remove them.
4. The water inlet valve is connected by two wires. Before disconnecting the wires please label the wire placement on the water inlet valve.
5. The wires are connected to the terminal with slip on connectors. Firmly pull the connectors off of the terminals ( don't pull on the wire ). You can use a pair of needle-nose pliers to remove the connectors. Please check if the connectors and terminals has corrosion. If corroded they should be replaced.
Hope it helps.
Thank you for using FixYa.
Nov 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking from under front. no water inside. removed front grill, can't see drip pan, where is it, want to check if over flowing.
you are looking in the right place it should be right under the bottom front of the refrigerator behind the grille. are you missing the condensate tray? (drip pan)
Jul 22, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Water leaking on floor
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Jan 21, 2010 | GE Refrigerators
We have a GE profile that we bought in 2007. We
Hi Sandy, I can assist you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jun 19, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Drain pan under ge sideby side fridge
pull the front bottom grill off then pull the pan out to you to drain or cleas.
Dec 16, 2008 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
