Question about Dell Computers & Internet
My Dell PowerEdge 600SC server seems to run OK but lately has a beep that is constant....no code just beep....beep....beep...I though it was the UPS system at first
  • 721 Answers
It doesn't match any Dell codes, I even checked on the site. I'd go into device manager & see if there's anything with an exclamation point & fix that first. Check under "my computer" (right click,properties) & see if it's reporting the proper amount of RAM. Then you can check in bios to see how much is showing there & what slot(s) they're in. Hopefully, you will quickly find the issue. A bad RAM stick is the "beep" code that you're hearing on most dektops in general. So if you see in the bios that a RAM stick is not showing or is incorrect in size, remove the suspected stick & re-boot to see if that takes care of the "beep". Then just go buy another stick & be sure to get eec if it requires it. Regular memory doesn't work in most servers.
Posted on May 14, 2010
I am getting a loud beeping sound from the back of my Dell Poweredge 1600SC Server this morning. It seems to be operating fine, and there are no warnings on the computer. It IS very dusty inside, though....
The sound may be an indicator alert. overheating, unlocked latch, etc. If the system is running ok and no noticable problems with your software, check your BIOS setting for log information related to alerts. If you find nothing of significate problems, you can disable alerts in the BIOS.
Hope this helps. Good Luck
C2Solutions
Jan 18, 2011 | Dell PowerEdge 1600SC Server
What operating system can be installed on Dell PowerEdge 600SC Server
depending on the amount of memory and processor speed i have installed windows 2000, windows XP. Linux, windows 200 server and windows 2003 server. it all depends on hardware requirements.
Jan 05, 2011 | Dell PowerEdge 600SC (Refurbished)...
How or where in the BIOS do I switch video source to PCI? Old Dell PowerEdge 600SC. Attempting to install new video board.
Most servers (including the 600SC) were not designed for use with add-in video cards, thus, there is no jumpers or BIOS setting to disable the onboard video.
Mar 13, 2010 | Dell PowerEdge 600SC (Refurbished)...
What audio driver to i need for my dell poweredge 600sc server running windows server 2003? Is there a direct link? I search and have not found anything.
dell poweredge servers are not needed for sound. DELL support will not support any sound cards or care anything about your audio issues. You will not find audio drivers because again, a server's purpose has nothing to do with audio.
Jan 11, 2010 | Dell PowerEdge 600SC (Refurbished)...
Can't install Windows Server 2003 on a Dell Poweredge SC600 Server, says invalid partition.
NTFS Will support up to 2TB Partition Size
255 file name length and nearly unlimited file number :)
Skype ID amit.bhardwaj4
Dec 29, 2009 | Dell PowerEdge 600SC (Refurbished)...
I want to add a sound card into the PCI Slot, but already have a USB card in. Is there an extender or Riser that allows the use of two cards? The ports within the cards need to accessed from the slots on...
I put in a sound blaster sond card in my Dell 600cs from Wal-mart takes the newer soundblaster card is notched to work with 64 bit slots i have a pair of Poweredge 600cs nice workstations one is dedicated for data recovery. sound blaster live will not work
Hope this helps same way for adding nic cars use server cars have the noch to fit.
Oct 12, 2009 | Dell PowerEdge 600SC (Refurbished)...
My Dell PowerEdge 400SC server seems to run OK but lately has a beep that is constant....no code just beep....beep....beep...I though it was the UPS system at first.
hello..this is the solution if u want to go back run properly the unit.remove the memory card SDR,DDR1 or DDR2..try to clean all pin connector using the paper eraser.Good Luck..Thanks and GOD DAY..^_^
May 16, 2009 | Dell PowerEdge 400SC Server
NO Audio out put
dell2_bing.gifpoweredge servers are not needed for sound. DELL support will notsupport any sound cards or care anything about your audio issues. Youwill not find audio drivers because again, a server's purpose has nothing to do with audio.
Jan 27, 2009 | Dell PowerEdge 600SC (Refurbished)...
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Computers & Internet Logo
471 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
