Question about KitchenAid 24 in. KUDS02SRSS Stainless Steel Built-in Dishwasher
Dishes not clean after wash cycle, even after heavy duty wash. I use Cascade and jet rinse.
  • 523 Answers
Prime the sink before starting the dish washer
Posted on May 14, 2010
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The dish washing powder does not wash out completely unless the machine is set to heavy duty only. we will often open the machine at the end of a wash cycle and see the soap powder all wet and soft but not...
Seems to be problem with spray arm pressure. Check the spray
arm jet nozzles.
Check the incoming water flow to the machine. clean the strainer fitted at the washing machine end connection.
Being in the extended warranty, take the help from
the service provider.
Aug 31, 2010 | Dishwashers
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher detergent is not completely rinsed from dishes
the washarms may not be going look for things in the wash arm holes and clean out . / ck the screens in bottom of tank / make shure you have fresh dergt (powder is best or lakt cascade w/ dawn tabs are best . rinse aid like jet dry / and hot water 140 deg / use hi tempt wash / and no heat in dry -- glass majic will clean up problem . then go back to the recom . dergt. mm
Dec 07, 2009 | Refrigerators
My dishwasher does not always dry the dishes completely - even though I use the same cascade with each use.
The most important thing to getting the best drying from this energy efficient, water conserving dishwasher is keeping the rinse aid dispenser filled. In my part of the US, I only see a rinse aid called Jet Dry.
The Cascade is the detergent powder and will not help the dishes to get dry.
Note: Even with the rinse aid full, some plastics will still be wet.
Aug 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishes and glasses won't clean
I try to use only green products however have found that only the recommended cleaner works. I use the Cascade gel action pacs and found also that if the rinse agent is near empty, dishes won't get clean. Hope that helps
Dec 16, 2008 | Bosch 24 in. SHX46A05UC Built-In...
Dishes still dirty after heavy wash cycle
There is a screen on the drain area of the bottom of the dishwasher that needs to be cleaned. It has a plastic mesh screen on it - you can't miss it. Second get an old toothbrush and clean out the little jets on the washing arms that spin around. You will notice these holes are clogged up with calcium deposits etc. Those things done you will have a new dishwasher again. You need to do this every 6 months or so. Also use a rinse conditioner for a while to assure the jets are clean. Good Luck
Nov 29, 2008 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
There is a heavy film on my dishes. I have a rinse in it but I don't think it is being used and I use Cascade gel to wash them?
A heavy film can be the product of bad water conditions, bad cleaning action from the machine, incorrect/inadequate chemistry, and even water temps being too low.
Start by washing some of the dishes by hand to determine if the film can be removed. Use a quality detergent and some elbow grease. If film can be removed, test the machine for proper washing action. I like to do this by coating the inside of several glasses with mayonaise and placing them strategically throughout the machine. Run a cycle and ensure ALL mayonaise is removed. Is mayo removed? If no, check for plugged wash arm jets or screens. If yes, check for good water temps. 120F or higher is best, depending on machine type/model.
If machine is good and film is removed by hand, then you either have a water problem (water hardness, TDS, etc), a temp issue (raise temps above 120F), or a procedural issue (improper loading of wares, inadequate/insufficient detergent, too much food soil entering dishmachine).
Hope this helps,
Kermit
Aug 17, 2008 | KitchenAid Dishwashers
KitchenAid 24 in. KUDS02SRSS Stainless Steel Built-in Dishwasher Logo
123 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
