Question about Canon EOS Rebel XSi Digital Camera
Canon Rebel XSi mirror problem
My Rebel XSi is facing mirror problems recently. In full auto mode it works fine. In manual mode, when I press the shutter button, the mirror moves up and gets stuck there. After a very long time (15 seconds or so) the mirror just comes down and there is no image recorded. If I press the shutter button again, when the mirror gets stuck, then the shutter opens up, records the image and the mirror comes down.
Mirror lock up option is NOT enabled, but still I face this problem. In auto mode I find no issues.
Has anyone faced an issues like this? Can someone help me out?
  • 34 Answers
SOURCE: Spot Meter on Canon Rebel XT?
there's a metering mode setting.
from the manual:
(metering mode on first menu1)
evaluative metering - standard setting, takes account off all areas of scene.
Partial metering - effective when background is much brighter than the subject due to backlighting etc.
Centre weighted average metering - the metering is weighted at the centre then averaged for entire scene.
pressing the right hand button of the two little ones top right corner of camera brings up display on lcd, using thumb wheel you can select where the metering takes place. in the viewfinder the display lights a red dot for areas selected.
Try these settings to see if this helps in your situation.
Posted on Dec 15, 2008
SOURCE: when I press the shutter button I can hear the
Does your blue print light come on? The blue light is just right of the menu button.
Posted on Feb 07, 2010
SOURCE: Canon 15-55 zoom: won't auto focus. My 70-300 on
focus ring on cannon ef70-300 zoom is stiff, jerky. how can i free it up.
Posted on Apr 26, 2010
SOURCE: My Canon Rebel XSi will not auto focus.
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Posted on Apr 29, 2010
  • 32 Answers
SOURCE: My camera (digital rebel xsi)
Sounds like either the shutter or maybe even the mirror. Are you able to see a picture through the viewfinder? If you can find a very clean area, try taking a long exposure (30 seconds) and and see if you can see the mirror through the lens. If you can see through the viewfinder, and the long exposure is still black, then I fear you are correct.
Posted on Mar 22, 2011
Testimonial: "I did the tests you told me, and unlucky for me it is the shutter sensor. Thanks a lot for your help."
I have a Canon XSI Rebel that I bought new 2 years ago. For some reason when I'm in AV mode I cannot seem to get the ISO down to 100. Is there a setting that I may have missed? When I have the cam
The AV mode is for setting the aperture (ie Depth of Field).
To change the ISO setting turn the Mode dial to the P position and then turn the Main dial (next to the shutter button) to the ISO setting you require.
Apr 08, 2013 | Canon EOS Rebel XSi Digital Camera
My Cannon Rebel XSi when pictures are taken are blurry
Try using manual focus. Make sure your auto focus points are correctly set. Look for button that looks like matrix. Press it then use/press joy stick type button to select auto focus point.
Nov 20, 2012 | Canon EOS Rebel XSi Digital Camera
DOES THIS FLASH WORK ON CANON REBEL XSI?
Yes and no. It will work fine as a manual flash, putting the burden of figuring out correct exposure on your shoulders. It will work fine in the automatic modes on a Nikon camera.
Quantaray makes a Canon version of the flash which will work in the automatic modes on the Rebel XSi.
Jul 27, 2010 | Quantaray PZ-1 DSZ for Nikon TTL Flash
My auto focus will not work.
lens af unit gear is broken, or lens af saft if broken, or lens af flex is broken.
or could be camera sub mirror spring is come out from mirror unit.
take it to canon repaire centre to estimate
Jul 05, 2010 | Canon EOS Rebel XSi Digital Camera
My canon rebel XSi will not auto focus
Apr 04, 2010 | Canon EOS Rebel XSi Digital Camera
Mar 14, 2010 | Canon EOS Rebel XSi Digital Camera
How do i turn my flash off canon eos xsi
In your camer there will be seven Full Auto modes : full auto, portrait,
landscape, close-up, sports, night portrait and FLASH OFF. Turn
the Mode Dial of the camera clockwise as far as it will go to
disable the flash. In Full Auto, the flash is also disabled in
landscape mode and sports mode.
Hope this helps.
Jan 24, 2010 | Canon EOS Rebel XSi Digital Camera
No matter what button I push on the Rebel XS EOS, I gat the message ''This function is not selectable in the current shooting mode''
What shooting mode are you in? In manual, the camera leaves most everything to you. In full auto, the camera does everything. Try some of the other modes to see if they offer the functions you want.
Dec 10, 2009 | Canon EOS Rebel XSi Digital Camera
Auto flash won't pop up
With the Canon XSi, the flash should automatically pop up in FULL AUTO mode when it thinks it needs to. In modes like Manual Mode, you need to pop it up yourself. There is a button on the front next to the lens that looks like a lightning bolt, that's the flash activator. Try popping your camera into Manual Mode and press that button. If it doesn't work then there might be a problem with the mechanism and needs repairs.
May 24, 2009 | Canon EOS Rebel XSi Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
149 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
