Question about GE HO98010 Computer Speakers
I INSTALLED THEM YESTERDAY AND I AM NOT GETTING ANY SOUND OTHER THANTHE POP WHEN I TURN THE POWER BUTTON ON AND OFF. HELP
    Brigadier General:
  • 10,406 Answers
Make sure that the small jack is connected to "audio-out" on your computer's sound-card (not "audio-in" and not "microphone-in").
Try connecting the speakers to an iPod - you might not get much volume, but you should get some, if you maximize the speaker-volume.
Posted on May 14, 2010
I replaced the power supply unit on my 50" ProScan flat screen and now it wont even turn on just a clicking sound when you hit the power button.
The replacement power supply could have been installed incorrectly or may have been defective as received.
Nov 20, 2014 | Proscan Televison & Video
Directed 10.2
remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
Oct 25, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
49 FF81 error on HP Laserjet 3035xs MFP
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter (see Formatter on page 116).
Apr 03, 2012 | HP LaserJet M3035xs MFP All-In-One Printer
Picture started getting fuzzy then it went out
yes,remove the back of the tv,on the power board you will see the problem.replace those capacitors on the power board.this will allow the set to work.the black bars may still be there.this is an indication of a bad panel.
Aug 08, 2009 | Televison & Video
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Engine wont start...
since have change new battery, will the motor turn over? if the engine turn over or crank, check if you have sparks, by pulling the plug out and ground it to the metal to the bike and turn the motor over and see if you getting spark, double check if you are getting fuel, two items to make the engine run, sparks and fuel. if the stater dont make any sound when you press the start button it may be faulty serenoid to the starter, check starter and starter switch. you can get a light tester and test positve and negative contact to your serenoid/starter by hold or pressing start button to see if you get power to the starter. hope that help some
Jul 16, 2009 | 2006 Suzuki RV 125 VanVan
MY L.G TV IS NOT WORKING
try turning it on by the power after you pull the plug and put it back in. press the channell up button to see if it will turn n, if it still makes this sound locate the personyou bought it from and let them know. hope you sill have warranty.
Jul 15, 2008 | Televison & Video
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
GE HO98010 Computer Speakers Logo
100 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
