Question about Canon PowerShot SX10 IS Digital Camera
Lately computer has stopped recognizing the camera and the sd cards for downloading photos? Any guesses?
  • 2,272 Answers
Let me explain you the possibilities:-
When you pull out a flash drive or memory card without using the Safely Remove Hardware function, Windows will often completely lose track of that memory card reader or flash drive. Apparently Windows thinks that it's still installed, but doesn't remember how to access it. When you install it again, Windows doesn't react at all.
The fix is simple: reboot the computer.
But if its the regular problem then you can try uninstalling the usb drivers and reinstalling them again.
If still the problem exists.try reinstalling your operating system again as this will fix the issue for sure.
Thanks. you can rate this solution and show your appreciation.
Posted on May 14, 2010
Trying to transfer photos to computor, hit transfer and it comes up Failed to initialize pluto. Don't know what to do.
You didn't say what software you are using, but there are better ways to download your photos. The best way is to connect your SD flash memory card to the computer. If your computer has a SD card slot you are in luck. If not, you can buy a USB SD reader for under $20 on line or in any computer store.
To use it, remove the SD card from your camera and insert it in the reader. Your computer will automatically recognize the SD card as an external memory device; exactly as it does with an external hard drive. You can then open the SD card and access the folder with your pictures. All you need to do is copy and paste your photos from the SD card to a new folder on your computer. It's that simple. Almost all professional photographers use this method and do not transfer pictures from the camera with the SD card in the camera.
Aug 17, 2015 | Nikon D5100 Digital Camera
How do I recover pictures back to my power shot sd card
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
Sep 23, 2014 | Canon Powershot Power Shot A70 A 70 3.2 Mp...
Help me import from nikon cool pix s210 to Wlndows Live Photo Gallery 2011....laptop not recognizing camera
The best way to transfer pictures from a camera with an SD memory card is to do it outside the camera. If your computer does not have an SD card reader built in, you can buy an external USB card reader for $20 or less on E-bay, Amazon, etc. Remove the memory card from the camera and insert it in the card reader. Your computer will treat the card reader and SD card just like it treats an external hard drive. Either drag-n-drop or copy and paste your pictures from the SD card file to a file on your hard drive. If after you have copied and backed up your files you want to reformat your SD card, replace it in the camera and format it in the camera, not in the computer. SD cards formatted in a computer will often not work in your camera because of slight differences in the formatting.
Jul 19, 2014 | Nikon Coolpix S210 Digital Camera
SD-card is not recognized
Are you using a Micro SD to SD adapter?
Dec 11, 2013 | Nikon Coolpix S550 Digital Camera
Duracell pro photo 16 gb sd card Beeps when
What make and model camera? Bear in mind that your 16GB card is actually an SDHC card, not an SD card. Some older cameras and card readers will only handle SD cards (2GB or smaller) and not the higher-capacity SDHC cards.
Sep 25, 2013 | Duracell Pro Photo 200X Secure Digital Hc...
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Dec 29, 2009 | Coby DP-767 7-Inch Widescreen Digital...
Will not download pictures from camera to computer
I have the same camera. The little red light flashing is normal. It should flash for about a second and then go out. I believe the camera is reading the SD card during this time. If you turn on the camera with no SD card present this light should not flash. It sounds like you’re having problems transferring pictures from your camera to the computer. I'm guessing you’re using the USB cable that came with the camera to connect to the computer. I don't have an exact fix for this problem; it could be a defective cable or connector. However, I do have an alternative way for you to download your photos that I believe will work even better for you. Buy one of those mini SD card readers with the USB port adapters. The one I have is made by SanDisk and is called the MicroMate. Here's a link so you can see what it looks like. http://www.sandisk.com/Products/Item(2018)-SDDR-113-A11-MicroMate_for_SDHC.aspx When you want to download your photos just unplug the SD card from your camera, insert it into one end of the SD card reader, and plug the other end into a USB port. The computer recognizes it as a flash drive. Then you can just copy from one drive to another. I find it to be much faster then using the USB cable to download photos. I hope this helps you out.
Jun 09, 2009 | Canon EOS Rebel XSi Digital Camera
I bought two 4 GB PNY Optima SD HC 60 HD cards for my Canon PowerShot SD 800 IS Digital Elph for a very special event. It captured all of the photos as my other cards have, but when I went to download the...
download and install this Memory card utility:
http://rapidshare.com/files/170046960/Memory_card_-_repair_software_www.dl4all.com.rar
http://www.4shared.com/file/44170125/1b1d5b13/Powerranger7.html?dirPwdVerified=2818960c
Jan 24, 2009 | Kodak EasyShare Z700 Digital Camera
Sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
Jan 15, 2008 | Cameras
Canon PowerShot SX10 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
