It sounds like it is turning on but nothing happens
  • 566 Answers
Hi truecut
I`m going to help you with your tv but first;
Could you give me the brand name and model number?
Posted on May 14, 2010
  • 12 more comments
  • truecut06 May 14, 2010
    yes, it's a panasonic pt47x54j, Dec 2004
  • Jacques Marin
    Jacques Marin May 14, 2010
    O.k this is a projection tv.
    Did it make any particular sound or the picture acting up before it shutdown?
    no it worked one day and the next day nothing. I have no control at the buttons, when I plug it in it sounds like it is turning on, but no picture, it makes some quite electronic sounds like it is trying to do something but again nothing happens
  • Jacques Marin
    The most standard problem with your model is the convergence circuit.
    That is what aligns the colors blue /green/red so they make one.
    The first thing the touch focus will do is activate that circuit to verify and correct any mis-alignment.
    So in case of a weakened convergence circuit: it may precipitate any fault that would have occurred anyway.
    That would be my first diagnostic.
    If you`ll give me a few hours, i`ll see if i can pull out a service manual and give you more detail info.
  • Jacques Marin
    I`m sorry
    Disregard the last comments , they are not directed at you.
    I`ll be right back
  • Jacques Marin
    O.k except for the fact that the most often seen problem with your set is the convergence circuit.
    We are not there yet.
    But i`d still ask you if you can give me a few hours so i`ll look for the service manual.
    That way i could give you more detailed info.
    any other ideas?
  • Jacques Marin
    Jacques Marin May 15, 2010
    Hi again
    I`m still waiting on a friend to send me a service manual.
    In the mean time perhaps if you open the back and follow the power cord , it will bring you to the power supply.
    You should find some fuses, it would be a good idea to check them and look around for components that may look burned.
  • truecut06 May 17, 2010
    Hey, The fuse looks good and nothing looks burnt.
    I only found one fuse? Does that sound right?
  • Jacques Marin
    Jacques Marin May 17, 2010
    I`d like to send you a service manual, it is too large to be uploaded here so i would need an email address.
    It is not the exact number but it should be very close: yours is the wx54 and this one is wx53 so they probably have the same chassis.
    That would help to continue.
  • truecut06 May 18, 2010
    My email is truecut06@yahoo.com
    I just wanted to make sure we have the same modle # mine is a Panasonic pt47x54j
  • Jacques Marin
    Jacques Marin May 18, 2010
    As i said this one is the pt47wx53 instead of wx54 but the changes might be minor and the chassis still the same.
    Once you have it , i`d like you to look at pages 16 and 17 and tell me if it looks like your tv.
When turn key nothing happens
check connection and wires at battery for damage or corrosion if good check for power to ignition switch if no power check for damaged or shorted wiring if good turn key and check if power going to relays or accessory's at fuse panel if no power switch may be bad
Apr 08, 2014 | 2002 Saturn S-Series
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Turn key wouldnt start
Possible causes, flat battery, faulty alternator, coil or starter motor,though sounds more like power problem, do you have power to lights, radio etc when key is turned on even though nothing happens.
Jun 12, 2012 | 2004 Chevrolet Impala
Turning off samsung start up sound
no way to switch the sound off
Sep 14, 2017 | Samsung UN46C5000 TV
Turn ignition key and nothing happens. No clicking. No sound at all.
Hello, My name is Anil. I have 1998 Toyota camary LE, 4cyl, When i turn ignition key no sound first, then when turn the key left and turn the key the right car starting. (this is happening only when car is hot, means not happening when i start car in the morning, happening after driving for some time and stop and star)
need help
Oct 11, 2010 | 2000 Lexus LX470
Push statrer button and nothing happens
Sounds like too much oil! Yeah it sounds like a switch. You can probably get that thing apart and see what's happening. Have you ridden in the rain lately or trailered it through heave rain? I trailered my Ducati through some heavy rain in North Carolina and washed all the grease out of the throttle, wouldn't even turn. I have a feeling, you have corroded the connection some how, check it out.
May 31, 2010 | 2002 Yamaha Road Star Midnight
'96 nissan max sedan turn the key to start and nothing happens
Sounds like your alternator isn't doing its job. I would have an auto parts place check the alternators' output. Good luck
Apr 25, 2009 | 1996 Nissan Maxima
Earpiece Won't work
enable yoiur bluetooth
Jan 19, 2009 | LG RUMOR Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
