Question about Philips 55PP9401 55" Rear Projection Television
Colors seem to be out of sync
As you view the screen the red color is misaligned counter clockwise and the blue is misaligned clockwise. This makes it difficult to read small writing around the outside of screen.
  • Philips Master
  • 3,459 Answers
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
Colors seem to be out of sync - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
Only showing blue red and black colors
It sounds like a display panel fault. Anyway make it sure. Check the site linked here. It has illustrations and details to faults to LCD display screens. Contact any service technician too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 11, 2013 | JVC LT-32D200 LCD TV
I need to wire my DJ-20 Jointer back to 230 and I don't have schematic Suggestions?
Assuming you have a standard dual-voltage single-phase motor, your wire colors should be:
T1 - Blue
T2 - White
T3 - Orange
T4 - Yellow
T5 - Black
T8 - Red
For 220V wiring, you want:
Line 1 (to Black wire from switch):
Blue
Black
Line 2 (to White wire from switch):
Yellow
Tied together with a wire tie:
Red
Orange
White
This should make it so the shaft spins counter-clockwise. If you need it to spin the other direction, switch the red and black wire from the motor.
Jun 23, 2010 | Delta X5 Dj20 8" Precision Jointer
Red, yellow and blue bars going through the screen, what does this mean and how do I correct it?
U mean ur tv have colors shadows?Colors lines Red,Green,Blue misaligns don't line up to produced a solid picture?U have a 3D pic?All these are cause by a problems known as CONVERGENCE PROBLEMS.Ur tv the convergence board the 2 convergence ICS and some or all it resistors are dead.All these parts on the convergencce board,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 15, 2010 | Toshiba TP50H50 50" Rear Projection...
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Sony dlp with red tint
This is a simple fix and not hard to do, first you must get the speaker grill off, usaly two screws on the bottom and they might be hidden under to caps, then remove the acsess cover from the front. From there you should see a control box with six controls, three on top of three,,,,One part label "screen" the other "focus" now turn the set on and tune to a input that HAS NO SIGNAL this should give you a black pix, probley not now but it's supose to be black. Now turn the ones marked screen , one at a time counter clockwise just a little to get the pix compleatly black, now starting with one color turn the control slowly clockwise till the color just appears then turn it back down till it just disapears (Black) do this for all three colors Now the set should runn
Dec 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Theres blue lines on my sony kf-42sx300u tv fell over and the mirror inside broke, so i bought a old tv for spares, rebuilt the tv first the lamp cover wasnt secured correctly thus making the tv not turn...
Dec 29, 2009 | Televison & Video
TV colors distorted
make a degosing coil or try to look for a website how to make it in the phillipine we only make it coz we can't buy or its not available in the marker ok thanks that is the only solution you can do k
about akai tv may be it just coldsolder in crt socket try to solder it thanks inform me
Sep 10, 2008 | Televison & Video
Three colors line up on some spots but not others
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Philips 55PP9401 55" Rear Projection Television Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
