Question about RTO 20 14" Abrasive Chop Saw Blades Metal Cut-off Wheels
I have a electric chop saw I use for gutting 41 x
I have a electric chop saw I use for cutting 41 x 41 galv channel. sometimes it just wont cut and seems to burn its way through leaving great big burrs
  • 843 Answers
David, If the only variable is the material and not different blades, different operators, different feed rates --- then the variable is just that, the material. Abrasive cutoff wheels actually work best on somewhat hard materials. They will make big burrs (this is known as galling) when used to cut softer material. And once a wheel starts to do this, it will tend to load up (just like fine sandpaper does when sanding a painted surface) - and this loading up will cause more galling and poor performance. You might be able to intervene by dressing the wheel. You might be able to do that with a carbide tool insert held in locking pliers. The variability of your galvanized channel can be come from the steel itself being softer sometimes, but might be mostly due to the varying thickness of the zinc plating (which is what galvanized is). Zinc is very soft. I hope you find this helpful. Al Kupchella
Posted on May 14, 2010
Can I use my metal chop saw to cut wood if I replace the blade with a wood saw blade?
Its conversely sometimes possible if you was asking about a wood saw with a steel saw blade but i cannot advice that in both application its not safe because not only of the difference of power but most it is the much higher RPM by diameter, just beware always on the max rpm you can read on your saw blades!!, it can give strange accidents with objects it can grab and swinging outbroken parts away.
Sep 28, 2016 | Makita "2414NB 14"" Chop Saw"
How to check the electric brake on a dewalt 706 type 1 chop saw
The power cord can get a break in it. Try moving it when this happens. Otherwise, the plug can fall out of the outlet. Sometimes the switch goes bad.
Jan 25, 2015 | Dewalt Saws
How do you remove the blade on my toledo chop saw
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
Sep 04, 2014 | Saws
Ts400 hard starting
Check the fuel tank vent, it could be creating a vapour lock in the fuel tank
Nov 05, 2013 | Stihl Concrete Cutoff Chop Saw Clutch...
How to change stihlsaw blade
Most petrol cut off saws have a 13mm bolt securing the blade.
Apr 01, 2013 | Milwaukee 6180-20 14" Chop Saw Abrasive...
The stone on my chop saw stops cutting. Why?
Sometimes the edgeof a cutting disk can become clogged with particles of the material being cut e.g. cast iron or soft metals.
Try cutting a piece of brick or other hard material to chip away the edge of the disk to expose new abrasive
Mar 30, 2010 | Dewalt Chop Saw D28700
Where can I find a blade bolt for a Chicago Electric Power Tool Chop saw?
Take the model number and serial number to Ace Hardware. They should be able to look it up for you and get the correct bolt in.
Jan 16, 2010 | Ace Hardware Ace Chop Saw Cut - Off Blade
RTO 20 14" Abrasive Chop Saw Blades Metal Cut-off Wheels Logo
265 people viewed this question
Top RTO Saws Experts
andy just round the...
Level 1 Expert
john h
David Hoff
Are you a RTO Saw Expert? Answer questions, earn points and help others
