Question about Gateway FPD2275W LCD Monitor
Display monitor problem
The problem then after i restart my computer no displat appear then.i turn off plug the open back hit F8 used all menu in that advance configuration.the problem still the same help me????
  • 180 Answers
That is something to do with the setting.
Posted on Apr 20, 2008
SOURCE:
Startup Repair cannot repair this computer automatically
Try booting into the Safe Mode and check if the issue persists.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words Safe Mode appear in the corners of your monitor to identify which Windows mode you're using.
1. Restart your computer. Click the Start button, click the arrow next to the Shut Down button, and then click Restart.
2. Do one of the following:
· If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
· If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter.
4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor. To exit safe mode, restart your computer and let Windows start normally.
To know more information on how to boot into Safe mode visit the following link:
Start your computer in safe mode
http://windows.microsoft.com/en-us/windows7/Start-your-computer-in-safe-mode
Method 2: Also scan the Computer for error using chkdsk command in the Command Prompt from the System Recovery Options Menu.
To open the System Recovery Options menu on your computer
1.Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
2.Do one of the following:
•If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
•If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3.On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.)
4.Select a keyboard layout, and then click Next.
5.On the System Recovery Options menu, click a tool(Command Prompt) to open it.
6. At the Command Prompt, type: chkdsk /r . Press Enter.
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
Apr 03, 2014 | Microsoft Computers & Internet
Hi, my 2009m monitor will not stay on and it is saying "no signal"
You can try to check if the video cable (VGA/DVI/HDMI) is connect properly from your Monitor to your CPU. Sometimes it is cause by a bad cable, bad video card or bad memory. I suggest that if the cables are good then you need to check the Video Card or the Memory Stick however, you need to be familiar on how to do it. because opening the CPU might void your warranty. So it is betting after checking the cable is to call the manufaturer or the computer if the computer is purchase from a certain company like DELL, LENOVO, HP ,etc. or call a local tech to help you to check it.
Thanks for using Fixya.
Jan 31, 2011 | HP 2009M Monitor
Monitor problem
If you restart your computer and either go to the Bios setup menu (usually by pressing DEL or some other noted key, in the first few seconds of power up) does the same "contrast" menu still appear?
If so, then it must be your monitor (likely Monitor, not computer)
Your monitor is mad at you and it is displaying a Warning Message that is part of its OSD (On Screen Display). Some monitors are more sensitive then others so it takes very little to get this type of message. To get rid of it you will need to use the buttons on the monitor to get into the OSD menus. You need to look for something like "OSD Settings" or "Warning Message Settings" which may be found under "Setup Menu" or "Options Menu". This all depends on the make and model of the monitor as they are all slightly different.
Once you find this area you will need to turn off a setting that will be called "Warning Messages" or "Display Notifications", again the wording may be different but the idea is the same. Once you find the setting you should have the choice to set it to "ON", "OFF" or to an amount of time it will display (5 seconds, 15 seconds etc...).
On my Viewsonic the setting is found under "Setup Menu", and then I turn off "Warning Notification".
GOOD LUCK!!
ps. If the display looks OK then there is most likely nothing wrong. The message appears because the monitor detects a setting that may be in error. If the message goes away after a bit and doesn't bother you, you may choose to ignore it.
May 24, 2010 | AOpen A75PF Monitor
Windows xp will not start, only leaves me with this message on a blue screen STOP: c0000218 {Registry File Failure} The registry cannot load the hive (file):SystemRootSystem32ConfigSOFTWARE or its log...
1) Restart your computer and when it's booting up press F8 and try and get it into safe mode.
2) Restart your computer press F8 and select last good configuration.
If methods 1 or 2 worked you can ignore the others.
NOTE: you might have to press a different F key then F8, but most times it's F8.
3) Get a hard drive enclosure and turn you internal hard drive into an external hard drive DO NOT FORMAT ANYTHING. From there just back up all your important data and return you computer to factory settings. (http://lifehacker.com/software/hard-driv…
4) Download Linux on a CD and use that as a live CD to boot up your computer and save your files. (http://lifehacker.com/software/disk-reco…
Aug 27, 2009 | Computers & Internet
Monitor says out of range
1. Turn off the computer.
2. Turn on the computer.
3. As soon as it starts up press and tap the F8 key.
3a. If a "boot menu" appears, select hard drive, press enter, and immediately press the F8 key again.
4. The safe mode menu should appear. If it does not, start over.
5. Select "Enable VGA mode".
6. The computer will now boot to native 640 x 480 resolution. You may now use the display properties to set it back to normal, within your monitor's range of course :c)
Thanks and please take a moment to rate this solution with a thumbs up, solved problem rating...after all I did just prevent your death :c) THANKS
Mar 30, 2009 | AOpen Black 17inch LCD, 1028x1024, 16ms,...
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
Oct 20, 2008 | Computers & Internet
Resolution is too high
You need to start the computer in VGA mode. To do that, turn on the computer. Keep pressing the F8 key every second until a boot menu appears. Select enable VGA mode. The computer will boot to a 640 x 480 resolution. From there you can go to your graphics properties and select a more suitable resolution for your monitor.
Jul 04, 2008 | Gateway GT5028 PC Desktop
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
20 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
